luccasoli Posted November 25, 2019 Posted November 25, 2019 [ref]onemanosx[/ref], Now the clicks work great, thanks! To be perfect, I think it just needs to be recognized as an apple trackpad (with those gestures), but thanks for the help! : D new send_me: https://drive.google.com/file/d/1Qvjyq4L2CKm8xqzQ6VLaywHiB-c5XZQt/view?usp=sharing to gain knowledge, can you explain to me what you did to correct?
kmbeatz Posted November 26, 2019 Posted November 26, 2019 Hello. I have a nice Lenovo 320-15IKB with 8250u CPU and a i2c Synaptics Trackpad. Its a SYNA2B3C. I have almost everything running but no Trackpad. Its working but it move and jumping. I have generate DSDT.aml with Clover F4 and add Windows 10 Patch and GPIO Patch. Please can someone help me. admins iMac.zip Systemreport 2.zip
artx.kras Posted November 26, 2019 Posted November 26, 2019 Hi! My TrackPad TPD0 not working Specifiers 0x57 Test from GPIO - 3F, 9F, C4, 84, 42, C2, AA, 17, 1B, 34, 55 . - no results Help, please! Send_me_Lenovo.zip kexts.zip
artx.kras Posted November 26, 2019 Posted November 26, 2019 Hi! My TrackPad TPD0 not working Specifiers 0x57 Test from GPIO - 3F, 9F, C4, 84, 42, C2, AA, 17, 1B, 34, 55 . - no results Help, please! Files DSDT.dsl - original and edit DSDT-dsl.zip
kmbeatz Posted November 26, 2019 Posted November 26, 2019 Hello. I have a nice Lenovo 320-15IKB with 8250u CPU and a i2c Synaptics Trackpad. Its a SYNA2B3C I have almost everything running but no Trackpad. Its working but it move and jumping. I have generate DSDT.aml with Clover F4 and add Windows 10 Patch and GPIO Patch. Sunrise Point-LP Serial IO I2C Controller #0 Signal processing co Signal processing co PCI0.I2C0 pci8086,9d60 IOInteruptSpecifiers <57 00 00 00 03 00 00 00> IONAME SYNA2B3C So the GPIO Pin must be 0x3F I I understand the Tutorial. 57 = 63 = Dezimal to HexDecimal = 0x3F But the Trackpad is not working properly Please can someone help me. DSDT Files Orifinal & IOREG File.zip Systemreport 2.zip
onemanosx Posted November 26, 2019 Author Posted November 26, 2019 o gain knowledge, can you explain to me what you did to correct? You did not patch for GPI0 controller. Check in BIOS if you can set trackpad to Advance mode. Added in 4 minutes 49 seconds: Its a SYNA2B3C. I have almost everything running but no Trackpad. Its working but it move and jumping. Remove VoodooI2CHID kext and use VoodooI2CSYNA kext. Set your device name in VoodooI2CSYNA info.plist like in the screenshot https://imgur.com/undefined Added in 12 minutes 55 seconds: Hi! My TrackPad TPD0 not working Use only VoodooI2C and VoodooI2CELAN kext.DSDT.aml.zip Reboot and extract new sendme. Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina)
kmbeatz Posted November 26, 2019 Posted November 26, 2019 Thank you. No I can't Set the Trackpad Mode in Bios. Its Minimalistic Bios shame on Lenovo Edit: OK I changed the Name in VodoooSynaptics Kext and deleted VoodooI2CHID.kext from SYNA2B33 to SYNA2B3C But the Trackpad is not moving anymore. In Verbose Mode I can see this Lines: pci8086,9d60 Found i2C device : SYNCA2B3C Incompatible APIC Interrupt Pin (0x57 - 0x2f) and no GPIO Interrupts found
onemanosx Posted November 26, 2019 Author Posted November 26, 2019 Incompatible APIC Interrupt Pin (0x57 - 0x2f) and no GPIO Interrupts found This message suggests that you should try interrupt mode with a valid pin. Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina)
kmbeatz Posted November 26, 2019 Posted November 26, 2019 Can you help me with that? Its beyond my skills sadly an English is not my main Language Sorry for that
onemanosx Posted November 26, 2019 Author Posted November 26, 2019 [ref]kmbeatz[/ref], Check if works. If not, extract new sendme after reboot with my DSDT. DSDT.aml.zip Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina)
kmbeatz Posted November 26, 2019 Posted November 26, 2019 Negativ I tried with VodooCHID.kext and after that with VodooSyna.kext With VodooCHID.Kext Trackpad working Partially and with VodooSyna.kext not working Send me File. http://www.mediafire.com/file/99f8l0e0ido6gki/Send_me_admins-iMac.fritz.box.zip/file Edit: I checked your edited DSDT.aml an saw that that you write SYNA2B33. I that correct? Because I have a SYNA2B3C Device Thank you sooo much sir
onemanosx Posted November 26, 2019 Author Posted November 26, 2019 [ref]kmbeatz[/ref], I only add the GPI0 pin. Nothing more. I didnt check against your config.plist. Disable XOSI and XDSM patches. I also see from logs that you did load VoodooI2CSYNA kext. You are still using VoodooI2CHID. Try this files. Replace (not merge) clover folder. Reboot. Extract new sendme. https://drive.google.com/file/d/1F5oyburR_OyQm-iZnZZNr-PhQ8YSMt6u/view?usp=sharing Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina)
luccasoli Posted November 26, 2019 Posted November 26, 2019 Check in BIOS if you can set trackpad to Advance mode. [ref]onemanosx[/ref], I dont have that option in bios =C so wouldn't it really be like me simulating apple's trackpad (with gestures)?
kmbeatz Posted November 26, 2019 Posted November 26, 2019 [ref]kmbeatz[/ref], I only add the GPI0 pin. Nothing more. I didnt check against your config.plist. Disable XOSI and XDSM patches. I also see from logs that you did load VoodooI2CSYNA kext. You are still using VoodooI2CHID. Try this files. Replace (not merge) clover folder. Reboot. Extract new sendme. https://drive.google.com/file/d/1F5oyburR_OyQm-iZnZZNr-PhQ8YSMt6u/view?usp=sharing Yeeeeeeeees Thank you sooooo much. Its working Perfect o mio. You are the Best. Marked Solved
onemanosx Posted November 26, 2019 Author Posted November 26, 2019 (edited) Yeeeeeeeees Thank you sooooo much. Its working Perfect o mio. You are the Best. Marked Solved Are you using the files from my Google drive link? Glad I could help. Added in 6 minutes 55 seconds: onemanosx, I dont have that option in bios =C so wouldn't it really be like me simulating apple's trackpad (with gestures)? You would also like to check if there are any BIOS update. If you have Windows installed, you can also verify that I2C device "AUI1667" is detected or some other names? There are cases where ACPI table calls a different name in OSX than in Windows. Is your device having multigesture in Windows though? And trackpad pref will only show with a working Battery Status. Edited November 26, 2019 by Guest Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina)
kmbeatz Posted November 26, 2019 Posted November 26, 2019 Yes I replace all the files from your Folder with my Clover Folder. Gesture all working Thank you sooo much Sir. Have a nice Day
onemanosx Posted November 26, 2019 Author Posted November 26, 2019 Yes I replace all the files from your Folder with my Clover Folder. Gesture all working Thank you sooo much Sir. Have a nice Day Enjoy! Your DSDT is fully patched. For brightness hotkeys remapping, read the topic in Useful Links. Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina)
luccasoli Posted November 26, 2019 Posted November 26, 2019 [ref]onemanosx[/ref], Yes, there was an update on bios, I updated last week (they were just security fixes). I don't have windows installed at this time, but when I was with it, I extracted a DSDT with Windows, do you think this DSDT can help? here: https://drive.google.com/file/d/1MuGg4Ntz88mZU6Q4Qpcu3ySELYizrNag/view?usp=sharing
onemanosx Posted November 26, 2019 Author Posted November 26, 2019 I don't have windows installed at this time, but when I was with it, I extracted a DSDT with Windows, do you think this DSDT can help? Go through Device Manager in Windows. Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina)
nikhilrathore_1999 Posted November 26, 2019 Posted November 26, 2019 [ref]nikhilrathore_1999[/ref], ETPD@1 is not a PIN number but instead it is an ACPI ID. This guide is generic for supported I2C trackpad or touchscreen devices Can u see my trackpad details and give me a solution to fix it for working full multigesture supportIMG20191126202423.jpg.zip
