I need help please , first time installing Hackintosh
so the problem on my first High sierra is the config?, i will try to upgrade directly to High Sierra from El Capita if it will no longer have this IO texts.
Added in 39 seconds:
Added in 49 seconds:
[ref]marvss4[/ref], 730 work in all system with native driver, don't need web driver
[ref]marvss4[/ref], some ppl use it in high sierra and mojave without problem
but if u want avoid problems, use RX560, very low price and real native support
also another question how to fix on About imac my graphics only shows 1gb instead of 2gb? i installed web drivers but still on 1gb. thanks for your help :)
[ref]marvss4[/ref], cosmetic, just ignore
