I need help please , first time installing Hackintosh
marvss4
So i tried tutorial on youtube i follow every step but after installing the High Sierra i was stuck on this text in black screen
IOconsoleeusers: time (0) 0->0, lin 0, llk 1. and
IOconsoleusers: gIOScreenLockState 3, hs 0, bs 0, now 0, sm 0x0.
i can only bypass this in safe boot and i cant install Clover in Safe boot.
My current build is
CPU:Intel i5 3470
Motherboard:MSI H61M-P31/W8
GPU:GT 730 2GB 128bit
RAM: 1x4gb kingston 1x8gb HyperXFury
HDD: WD 500GB
Link to comment
Share on other sites
[ref]marvss4[/ref], try it
https://Olarila.com/files/Utils/nvidia-update.command.zip
Added in 9 minutes 33 seconds:
[ref]MaLd0n[/ref], use it and run script above
CLOVER.zip
Link to comment
what will I do to the Clover.zip? should I copy it to the EFI folder? and paste and replace the clover files? or delete the clover folder and copy the one you give? :)
Added in 40 seconds:
CLOVER.zip
I tried the Nvidia command but it still persists the IOconsoleUsers: time (0) 0->0, Lin 0, elk 1, IOConsoleUsers: gIOScreenLockState 3, hs 0, bs 0, now 0, sm 0x0. :(
Link to comment
thanks, but after doing that and installing Nvidia installer command I still having this problem upon restart IOconsoleUsers: time (0) 0->0, Lin 0, elk 1, IOConsoleUsers: gIOScreenLockState 3, hs 0, bs 0, now 0, sm 0x0., I have to do nv_disable=1 over and over to keep booting and I can't seem to find a way to fix it and my resolution are so crappy and glitchy :(:(:(
Link to comment
[ref]marvss4[/ref], use a fresh install and follow procedure above
Link to comment
[ref]marvss4[/ref], 730 work in all system with native driver, don't need web driver
Link to comment
so the problem on my first High sierra is the config?, i will try to upgrade directly to High Sierra from El Capita if it will no longer have this IO texts.
Added in 39 seconds:
Added in 49 seconds:
Link to comment
[ref]marvss4[/ref], some ppl use it in high sierra and mojave without problem
but if u want avoid problems, use RX560, very low price and real native support
Link to comment
