RX 580 Nitro + 4GB and 4k monitor
I was living a dream, with my GTX 970 in the High Sierra. Then I had an opportunity to buy a RX 580. Thinking it would be even more compatible with the macos. Until I get home, and I install it on my machine.
I use a 4k UHD Philips monitor. But in RX 580 it does not work on macos, only on windows. The strange thing is that on windows works 100%, 4k in 60hz on HDMI 2.0. If I put in my old Samsung fullhd 27, it works normally. 1080p 60hz
Video with the problem ...
https://www.youtube.com/watch?v=o5NHWho79_0
As you can see in the video, Mojave recognizes it as a RX 570. And then I discovered this ... https://www.extremetech.com/gaming/279010-amd-launches-new-rx-580-with-fewer- stream-processors
Monitor
https://www.philips.com.br/c-p/288P6LJEB_57/brilliance-monitor-lcd-ultra-hd-4k
My setup.
Gigabyte Z97-D3H
i7 4970
RX 580 Nitro + 4Gb
16 gb corsair Vengeance 1866 Mhz
1 TB 7200 rpm
Corsair Neutron Gtx 120gb
Corsair CX750
Corsair H90 - 250
Corsair 500R - 350
:help
in macos, 4k 60 only in DP
