Need help, i5 3380m HD4000 sleep can't wake up
This laptop is I5 3380M HD4000, thanks to @MaLd0n for making DSDT for me, thank you.
Now that I have a problem, the wake-up screen does not light up after sleep. I can only press and hold the power button to turn it back on.
Looking at system.log, search for the wake keyword to get the following information:
This is because I do not know what causes it, how to address the need?
[ref]mosun1[/ref], without patched DSDT work?
No, I use the dsdt.aml you provided to me, I have not patched it.
I still don't know what patches are needed to solve this problem.
what should I do?
[ref]mosun1[/ref], remove DSDT and test wake, let me now
Sorry, I can't do the test now, the laptop is not around me, I am at home now, and the laptop is in the company. I will test it tomorrow morning.
I just finished testing and the situation is better than I expected.
Now let's talk about the test situation:
1, using dsdt.aml
(1) can sleep, but can not wake up, the screen does not light up after wake-up
(2) USB power is lost after sleep, and the device cannot be woken up by USB (according to the power indicator).
(3) closing lid can not sleep
2, do not use dsdt.aml (set the DSDT name to bios.aml in the clover boot interface)
(1) Normal sleep, power button wakes up normally
(2) After sleep, USB is still powered, and the device can be woken up by USB, and the screen is displayed normally.
(3) Cover the normal sleep, open the cover to wake up normal.
[ref]mosun1[/ref], :guitar
I have restarted the machine, use dsdt.aml to test the closed sleep, and found that the cover is sleepable, the cover can also wake up, but the screen is not bright.
Does this need to modify dsdt.aml to solve these problems? Need your help, thank you
u can apply only essentials, like irqs and let the clover work too
Do I need to discard dsdt.aml? But without your dsdt.aml, the device/PCI is empty, which doesn't look too good. Can't it be solved by modifying dsdt.aml?
[ref]mosun1[/ref], i apply all in DSDT, essentials, cosmetics, etc
u can apply with SSDTs too
[ref]mosun1[/ref], don't need open new
the screen stay black after wake?
Yes, the screen does not show up after waking up, I need to solve this problem
