Installation problem - Disk is not suitable for Mojave ?
I have been using Olarila 10.13.4 and everything was working. Now I am trying to upgrade to Mojave to get new Xcode and have a following problem.
Installator says it cannot install OS onto my Disk(it is the same model which worked with 10.13.4). I tried to erase it, and install with APFS and MacExtended file formats. (GUID of course)
Disk is SSD GoodRam CX300
[ref]merokotos[/ref], some SMBIOS loose support in Mojave, u just need one with support
[ref]merokotos[/ref], u just need use other smbios with support
[ref]merokotos[/ref], a good example, iMac12 don't work more in Mojave, for install and work we need iMac13, need check what macbookpro smbios stay with support in mojave
[ref]merokotos[/ref], notebook is optimus or no?
is just a driver, u need a correct driver for ur nvidia
[ref]merokotos[/ref], DSDT.aml.zip
U need use IntelHDGraphics and disable Nvidia
