AXE Posted November 18, 2018 Share Posted November 18, 2018 Hi, I tried different solutions (even different, old os versions), but I couldn't even get into the osx installer. Here are my machine specs; CPU: Intel Core i7 5820K, Haswell-E/EP, Socket 2011 LGA Motherboard: MSI X99S SLI PLUS (MS-7885), Chipset Haswell-E Rev. 02, Southbridge X99 Rev 05 RAM: 32Gb, DDR4, 1066.5 MHz (4 x 8Gb slots) GPU: NVIDIA GeForce GTX 970 4 Gb GDDR5 Disks: 3 x SSD (250Gb, 500Gb, 500Gb), 1 x SATA (500Gb) I downloaded Olarila Mojave, burned to USB with Win 32 Disk Imager and didn't touch anything else, but it won't boot (error: "Can't allocate bla bla bla"), so I tried with different drivers like explained in tons of other threads but it didn't work. Any help would be greatly appreciated! Thanks Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted November 18, 2018 Administrators Share Posted November 18, 2018 [ref]AXE[/ref], is a common problem in x99 u can check a start discussion here https://nickwoodhams.com/x99-hackintosh-osxaptiofixdrv-allocaterelocblock-error-update/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE Link to comment Share on other sites More sharing options...
AXE Posted November 18, 2018 Author Share Posted November 18, 2018 [ref]AXE[/ref], is a common problem in x99 u can check a start discussion here https://nickwoodhams.com/x99-hackintosh-osxaptiofixdrv-allocaterelocblock-error-update/ I already tried with OsxAptioFix, OsxAptioFix2, OsxAptioFix3...no luck... Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted November 19, 2018 Administrators Share Posted November 19, 2018 check if bios have 4G option -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE Link to comment Share on other sites More sharing options...
AXE Posted November 20, 2018 Author Share Posted November 20, 2018 check if bios have 4G option What's 4G? I don't think I've never seen it in my bios... Link to comment Share on other sites More sharing options...
laudou Posted November 20, 2018 Share Posted November 20, 2018 Axe I have the exact same configuration as you have MSI X99 SLI Plus and i7 5820K and I was eventually able to install Mojave 10.14.1 using the tools downloaded from this site (after days of frustration and help from MaLdOn). I don't know if I am allowed to upload my EFI folder here: you might want to give it a try. Link to comment Share on other sites More sharing options...
AXE Posted November 21, 2018 Author Share Posted November 21, 2018 Axe I have the exact same configuration as you have MSI X99 SLI Plus and i7 5820K and I was eventually able to install Mojave 10.14.1 using the tools downloaded from this site (after days of frustration and help from MaLdOn). I don't know if I am allowed to upload my EFI folder here: you might want to give it a try. That would be really cool, can you please provide your EFI folder? Link to comment Share on other sites More sharing options...
laudou Posted November 21, 2018 Share Posted November 21, 2018 I compressed my EFI folder but the file is still too big to be uploaded on this site:19.4MB. Do you have any idea how I could send it to you? Link to comment Share on other sites More sharing options...
AXE Posted November 21, 2018 Author Share Posted November 21, 2018 I compressed my EFI folder but the file is still too big to be uploaded on this site:19.4MB. Do you have any idea how I could send it to you? Just replied to your PM. Link to comment Share on other sites More sharing options...
AXE Posted November 21, 2018 Author Share Posted November 21, 2018 I compressed my EFI folder but the file is still too big to be uploaded on this site:19.4MB. Do you have any idea how I could send it to you? I followed these steps: 1) created the USB with Olarila Mojave 2) deleted the EFI folder 3) copied your EFI folder but the PC won't boot at all from that USB. Do I need to ADD your EFI content to the one created by the installer, or am I missing something else? Link to comment Share on other sites More sharing options...
laudou Posted November 21, 2018 Share Posted November 21, 2018 You have to follow all the steps described in the Mojave installation video, including installing Clover on your usb drive. Then you copy my EFI folder and paste it in the EFI folder of your usb drive that is mounted after installing Clover. A message will ask you if you want to keep both EFI or replace the original one with the one you are pasting; choose replace. When installing on your computer select boot from USB at the Clover boot window. You may get a few "Could not allocate runtime area" but keep trying and it will eventually boot. It is working fine here. I just tested it again before replying to your email. Good luck. Link to comment Share on other sites More sharing options...
AXE Posted November 21, 2018 Author Share Posted November 21, 2018 You have to follow all the steps described in the Mojave installation video, including installing Clover on your usb drive. Then you copy my EFI folder and paste it in the EFI folder of your usb drive that is mounted after installing Clover. A message will ask you if you want to keep both EFI or replace the original one with the one you are pasting; choose replace. When installing on your computer select boot from USB at the Clover boot window. You may get a few "Could not allocate runtime area" but keep trying and it will eventually boot. It is working fine here. I just tested it again before replying to your email. Good luck. Since there's quite a few material around, which video are you referring to in particular? Link to comment Share on other sites More sharing options...
laudou Posted November 21, 2018 Share Posted November 21, 2018 [Guide] Sierra / HighSierra / Mojave on Serie 5, 6, 7, 8, 9 / DSDT Link to comment Share on other sites More sharing options...
