waiting for remote debugger connection kdp_poll problem
After installing Olarila Sierra
boot from USB A problem appears
When used (-x) safe mode I can login to the Mac Only
  • My Computer Specifications :
    HP 280 G2 MT (non-legacy)
    CPU : Intel® Core™ i3-6100 Processor
    internal GPU : Intel® HD Graphics 530
    external GPU : ati radeon 3450
    Intel H110 Chipset
    RAM : 8G DDR4
Also I used internal GPU : Intel® HD Graphics 530 only Tested using inject intel & Without using inject intel The same problem :shock:
Thank you ..
remove the ati card, is old and maybe unsupported
use last Lilu kext + whatevergreen kext
https://github.com/acidanthera
[ref]artur-pt[/ref], Thanks for helping, you've followed the steps
But so far the same problem, Also when trying to install Olarila HighSierra This message appears in Intel® HD Graphics 530 inject intel & Without using inject intel
Panic - Please go to https://panic.apple.com
thank you ..
[ref]MaLd0n[/ref], how to enable Intel® HD Graphics 530 , show 6m,Is there a video explaining the method in detail
I using Clover Folder Serie 100.200.300
Thank you ..
[ref]amro-agha[/ref],
ig-platform-id 0x19120000
Check InjectIntel
Check InjectIntel
[ref]MaLd0n[/ref],
After many failed attempts, I think he should do a purchase external GPU !
Any suggestions about the appropriate pieces for my device , The Mac system is supported :frantics
A second question, please
AMD Radeon™ R5 320 1GB DH PCIe x8 is supported to mac ?
thank you ..
[ref]amro-agha[/ref], go to RX560
[ref]amro-agha[/ref], yes, RX560, RX580 or RX590
