How to Stay within 15 ports limit using UsbInjectall and Clover boot argument
And a follow up question... Is there another fairly simple way to exclude these ports if this method isn't working on this machine for whatever reason?
One of the things that I loved about this method was that it was the only one I found that I felt confident enough to do. :D
[ref]MAP002[/ref], Its even weirder than you do not have the uia boot arguments in your current clover. :mrgreen:
Anyway, there is another alternative which also achieve similar results. Check out Hackintool. Its really an amazing app! https://www.insanelymac.com/forum/topic/335018-hackintool-v177/
And yes, I have to agree this method is also the quickest and simplest to implement.
:cap:guitar:guitar
Donate
Gitter Chat
MSI B360 Gaming Arctic
Bloody heck! :D OK, time to investigate... :D
:boxing:mrgreen:
Donate
Gitter Chat
Somehow made a copy the Clover folder in the root of my EFI volume and was happily modifying that one instead of the real one. :D
Moral of the story: Bleary eyed late night/early morning hacks sometimes take some stupid turns. :D
:lol::lol: So now it works, I hope?
Donate
Gitter Chat
It does! :)
But after installing the new update, i do notice some of my USB peripherals, like my webcam, have gotten flakey, cutting in and out or freezing up intermittently. I'd love to get my USB working more reliably, but that might be as good as it gets with a Hack and this mobo, I suspect.
Thanks again for all the help. :)
I have a few questions if someone wouldn't mind explaining...
I'm just interested to know if there are any benefits or differences to creating an ssdt to remove unused ports Vs this method? This is a bit simpler to implement, I don't know why people would bother with ssdt.
Also, can you include 3rd party usb ports, on RP03 for example, with the uia boot arguments? I tried to guess what that would be but it causes all the boot arguments to fail. I have NEC/Renesas USB controllers on my mobo.
Finally, relating to the NEC/Renesas USB controller, are the RP03/RP04 ports included in the 15 port limit? They don't appear under the XHC section in IORegExplorer but don't appear without usbinjectall.kext (even when I have only 5 ports loading via uia_include) so I don't know if this is due to the port limit or because Apple simply won't include/have no need to include them in the OS.
Sorry for the long questions, I'm still learning and trying to figure out what's going on! :)
[ref]Andy4Shurr[/ref],
1. With SSDT, you may specify details of the ports as being internal/external or a USB C type connection. Using boot arg + usbinjectall method, the port type is reliant on the injector kext itself. That's the only difference.
2. This method as well as any other guides using usbinjectall kext only applicable to xhc devices with intel chipset only. Thus, other chipset/controller does not fall under the 15 ports limitation, afaik.
Donate
Gitter Chat
[ref]thief_fighter[/ref], no idea with how usbinjectall kext reacts when placed in other than clover/kexts/other folder.
Donate
Gitter Chat
make sure you delete all the kexts in S/L/E or L/E, rebuild permissions and reboot. I have not tried the latest clover yet, though.
Donate
Gitter Chat
try using a correct smbios as it should be imac 18,3
disable sip
:superman:superman
Edit: I was stupid, I have been booting from Clover in the backup external HDD, because my BIOS will auto choose the last select boot device as default.
No wonder why no changes in Clover in the internal SSD worked. :wallbash:wallbash:wallbash
Thanks for all the help guys!
Hi may i know. When i exlcude HS of course my keyboard and mouse on HS port will be disable. Why do u ask me to includeHS when in the first place it is exclude. I dont get what ur guide ask me to do. Im now only able to discover my HS port. After that. Im getting confused.
[ref]alpha1718[/ref], you use the incl boot argument for keyboard and mouse. So they will still function and not affected by the excl boot arguments. Useful when you are doing the port detection tests.
Donate
Gitter Chat
This happened to me too. I tried a few things but then I realized I could still control the machine from my one of my other macs via screen sharing, so that got me through it.
all is good tested an works
:superman:superman
[ref]rtga[/ref], [ref]alpha1718[/ref],
No idea why you guys are having issues. As can be seen here, I incl HS09, HS10 and HS14 and uses the exclude boot arg to only show SSxx ports. Works as expected. My tests to confirm is also by means of using the latest usbinjectall kexts (0.7.1 as of this writing) and latest clover release v4871 (as of this writing).
[ref]erroruser[/ref]'s, example is also prove that there is nothing wrong with his boot arg as well.
Ensure your keyboard & mouse ports are determined correctly by means of ioreg and boot arguments are valid.
1296334735_Screenshot2019-03-01at6_44_48PM.thumb.png.328e81904d2cd433a3883e5760a6c139.png
Donate
Gitter Chat
boot args i used uia_include=HS09;HS10:HS02 -uia_exclude_hs with a new usbinjectall kext from rehabman here https://bitbucket.org/RehabMan/os-x-usb-inject-all/downloads/RehabMan-USBInjectAll-2018-1108.zip
-uia_exclude_ss to remove ss
:superman:superman
[ref]erroruser[/ref], :meeting
Donate
Gitter Chat
[ref]onemanosx[/ref], :superman
:superman:superman
Hi! I finally installed Mojave and everything worked ok except the USB
So I followed several guides how to fix it, posted here... but finally I used the Hackintool app, that helped a lot to determine the USB ports in use.
I combined part of the method posted here, and the uploaded guide on this video:https://www.youtube.com/watch?v=Ye5YHUDcZ6Y
Now,I have all the USB ports working correctly
many thanks for all the help, galera!
