How to Stay within 15 ports limit using UsbInjectall and Clover boot argument
Just use back port. Front hub not reliable
Thank you very much :D:D
Added in 6 minutes 8 seconds:
Just use back port. Front hub not reliable.
Note: if you look at my clover folder I set for you, there is no injector kext :mrgreen:
Thank you very much :D :D
19 pin headers dont work well. Mine only detects as usb 2.0[ref]ruglau[/ref],
Donate
Gitter Chat
MSI B360 Gaming Arctic
[ref]ruglau[/ref], thats weird.
Donate
Gitter Chat
Hi guys,
I followed the guide, but it does not work for me, the kind @Mald0n created me a ssdt, thanks again!
I use this in boot arg.
uia_include=HS01;HS02;HS03;HS04;HS05;HS06;HS07;HS08;HS09;SS01;SS02;SS03;SS04;SS05;SS06
but it still does not work even with uia_exclude etc. etc.
any solution is welcome, thank you very much :bye
Added in 55 minutes 55 seconds:
Miracle of miracles ....
it's not what I wanted but it's okay anyway
238247139_Schermata2019-01-11alle21_56_19.thumb.jpg.18e0c3b44d5ca00086f692d7d2f2791b.jpg
1424666934_Schermata2019-01-11alle22_53_28.thumb.jpg.740ee68baa4eae6915644ea4e961ec5c.jpg
Hi onemanosx, I go through your tutorial, and it's working perfectly! I only mention for other user that ... on your youtube tutorial when you exclude USBports, in the text below you use "space" after "=" uia_exclude= HS01
When you type this with "space" in IORegistry it doesn't work ... so beware of "space" :whistle
Of course you type this in program correctly, but I first look at the text below.
[ref]denisgrusz[/ref], did you also read the guide :whistle
:superman:superman
[ref]denisgrusz[/ref], :cap:guitar
Donate
Gitter Chat
[ref]ruglau[/ref], ur bios have only a xhc device, don't need rename
good! I supposed that..when use uia_include=XX I have to include also the two HUB2.0 that I see on IOREG and that are connected to motherboard directly (powersupply usb control and ARGB usb control)?
And why -uia_exclude have dash in front and uia_include not?
Chck out Rehabman's link in post #1
As long as your resulted final ports is equal or less than 15 ports you may include whatever ports you may wish as detected during your troubleshooting procedure.
You have only a choice of 15 ports in total. Choose wisely.
Donate
Gitter Chat
Obrigado! Funcionou perfeitamente aqui! ;)
:guitar:guitar:guitar
Donate
Gitter Chat
When I run Blackmagic speed test, the USB 3.0 ports with my Kingston DT50 write speeds is lower (around 5mb/s) than the USB stick in USB 2.0 ports (around 6mb/s). The read speed is better in USB 3.0.
I've tested in Intel and Renesas ports.
There's a way to get better or my flashdrive is garbage itself? :lol:
1352345570_ScreenShot2019-01-19at11_56_21.thumb.png.7b9f6673f0f2e43dc9a7a3c64f1fa820.png
Mac OS CATALINA [OpenCore]
GA-Z97X-UD5H-BK | Core i7 4790k | Radeon RX 580 8GB | Samsung m.2 960 EVO
OK, so... :D I added the followiong to my boot arguments...
uia_exclude=HS03;HS04;HS09;HS10;HS13 shikigva=60
then saved and rebooted. BUT, after reboot, IOReg app still shows the excluded ports as active. What dumb thing am I missing? :D
[ref]MAP002[/ref], u need usbinjectall if use flag
[ref]MAP002[/ref], No idea why it does that. Do you also have xhci unsupported kext also?
Donate
Gitter Chat
