How to Stay within 15 ports limit using UsbInjectall and Clover boot argument
I am using a USB C hub to test. Do you have any USB C type devices?
Not actually, I just ordered a USB C to 2,5 HDD cable from internet, it has being detected sometimes as USB 3 with up to 5GB/s, not 10GB/s as it should. Im I doing something wrong ? :oops:
Hack Pro: Asus Strix Z590i, i9-11900K, RX 6900 XT, 1TB Samsung QVO SSD, RAM 16GB Corsair RGB @3200Mhz (Big Sur) OC
Hackbook Pro: (MSI GE63 Raider RGB) i7-8750H, Intel UHD 630, GTX1070 8GB(disabled), 16GB RAM @2666Mhz (Big Sur) OC
Not actually
Then, your journey ends here LOL
You will need a proper Gen 2 type USB 3.1 device to confirm
Donate
Gitter Chat
MSI B360 Gaming Arctic
:bye:lol:
Ok will try to search, is there any devices recommendation ?
Something like this maybe ?
https://www.amazon.de/CSL-Verteiler-Power-LED-Hohlstecker-Alu-Gehäuse/dp/B06VSXMNZG/ref=sr_1_3?ie=UTF8&qid=1543372653&sr=8-3&keywords=usb+typ-c+hub
https://www.amazon.de/CSL-Verteiler-Pow ... +typ-c+hub
Thats a USB 3.0 type C hub. Btw, does your board support USB 3.1 speed? As far as I know, not all USB type C are USB 3.1 Gen 2.
Donate
Gitter Chat
Its Gigabyte Z370N Wifi and it has USB 3.1 Gen1 with USB Type-C.
I just wanted to make that port usable no matter if high or low speed, I might order a USB Type C flash drive with 150MB/s speed, better than non :roll:
Then, the hub is suffice.
Your board does not support 10gbs speed.
Donate
Gitter Chat
You're right! Just checked mobo specs but as I said not a big deal if I can just make it usable for anything, thanks for the help :)
[ref]M0001[/ref],
explain more doesn't make sense :wallbash
...has anyone done the testing on an Aorus Z370 Gaming 7 board yet?
As in, are the results from one system good for another with the same motherboard, aside from where the keyboard/mouse are plugged in?
Also, in the port limit, are ports on a connected hub included? If so, I guess I'd be trading hub ports for on board ports.
[ref]M0001[/ref], it is always best to implement personally for your own build to avoid conflicts,if any. Port limitation are for onboard intel chipset. Any external hubs are not taken into account.
Donate
Gitter Chat
[ref]tarantababu2002[/ref], Please insert all USB ports with your USB device and run this app http://Olarila.com/files/Utils/RunMe.app.zip and upload the output folder.
[ref]onemanosx[/ref], Hi...
Before your patch all ports run like 2.0 except 3.1 port. After your patch USB 3.0 ports work with no problem but the USB 3.0 hubs work like 2.0. however, there is no 2.0 ports that can be seen in both cases, only usb 3.0...
Send me (Before the patch).zip
Send me (After the patch).zip
[ref]tarantababu2002[/ref], here is my comment
1. SSDT is pointless without a DSDT. Not required. Your SSDT is not even configured to your specific.
2. Boot argument - You should choose either exclude or include method. I propose exclude method.
3. You are using a 2.0 hub on a USB 2.0 port. Hence the 2.0 speed.
4. Non related - You are running full IGPU acceleration alongside your Radeon setup. Quick sync doesnt require igpu to run on full acceleration.
I also suggest you have your DSDT properly patched - visit here https://Olarila.com/forum/viewtopic.php?f=19&t=1131
Edit: I also suggest you test the ports again properly by using a USB 2.0 device to test for HSxx ports and use a USB 3.0 device to test for SSxx ports.
Donate
Gitter Chat
[ref]onemanosx[/ref] I have read your comments and,
1- Deleted SSDT-UIAC.aml from Clover
2- Prefered only exclude method
3- My hub hardwares are USB 3.0 but works only up to 480MB, by the way 2.0 hub looks like 3.0 hub on system report window
4-I'm using full IGPU acceleration for video rendering and photo editing works. I don't know the best config for this subject. I have tested all ports (2.0-3.0) and result is the same. I'll send my sendme file for giving help for DSDT.
Great thanks my friend
1273111378_ScreenShot2018-12-06at17_37_11.thumb.png.3fbc75e3a21ccbc44476290622faa0b3.png
You should be looking at ioreg instead of system report window. See my screenshot. HS01 is a USB 2.0 speed although physically you are using the USB3.0 port. SSxx is USB 3.0 speed. To get USB 3.0 speed you should be connecting to a SSxx port.
I suggest you do the USB test again after DSDT is patched by our good friend @Mald0n
Donate
Gitter Chat
Hi, i use -uia_exclude_hs to show all available port but maximum ss port visible are only 3 , total i reach 13 as port limit so i should have another 2 port, also my usb 3 i loaded from same usb port that is not showed in the ioreg .
My motherboard is an msi pro carbon z270
[ref]simo241[/ref], How many physical USB 3.0 ports do you have? Can you try with other USB 3.0 device to confirm detection? I know my "USB 3.0 supported all in one card reader" is not reliable for this sort of task.
Donate
Gitter Chat
Onemanosx, yes i did try also with a 3.1 usb and is loaded , i can use it but is not showed in ioreg, my concern is also that i arrive at maximum ss7 even if i still reach 13 port , where are tje other port ?
I just wonder if maybe are showed in eho1 section
