MayoMan Posted June 8, 2019 Posted June 8, 2019 [ref]MayoMan[/ref], your device id dont require xhci-unsupported kext. I say, generate with hackintool and see how it goes. Using uia exclude is more simplistic and the only downside, the method will specify every port as external. Thank you sir, i will report back Added in 44 minutes 34 seconds: [ref]MayoMan[/ref], your device id dont require xhci-unsupported kext. I say, generate with hackintool and see how it goes. Using uia exclude is more simplistic and the only downside, the method will specify every port as external. PS: Did you disable port limit patch? I use hackintool to generate my ssdt, in doing that it generate a file called "SSDT-USBX.aml" and USBport.kext as well. Placed both aml in patched folder with DSDT fix from MaLd0n. Did not use the USBport.kext though. Now it works correctly Nope i did not disable port limit patch Thank you so much sir!!!
onemanosx Posted June 8, 2019 Author Posted June 8, 2019 [ref]MayoMan[/ref], Yes, you should only use either ssdt or kext. Glad it works out for you! Congrats! Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina)
