How to Stay within 15 ports limit using UsbInjectall and Clover boot argument
:guitar:guitar:guitar
:guitar8-):guitar
:superman:superman
Discovering Ports in batch and exclusion of ports used by keyboard and mouse
Other esteemed hackintoshers may want the option to discover their used USB ports in batches i.e implementing HSxx then SSxx/SSPx. This method will reveal each HSxx/ SSxx/SSPx batches in one pass.
1. Discover ports used by USB Keyboard and Mouse
- open the app ioreg and look for the ports used by Keyboard and Mouse
- in my case its HS09 and HS10
- therefore, I include the following boot arguments in clover like so uia_include=HS09;HS10
- doing this you will have control over your keyboard and mouse when you use exclude_hs identifier
2. Identifying HSxx ports only and exclude all SSxx/SSPx identifiers
- add these 2 boot flags
a. -uia_exclude_ss
b. -uia_exclude_ssp << no longer required as per 9 Nov 2018 latest commit
- reboot and discover all of HSxx ports using USB 2.0 device like in the video link
- write down the discovered ports on a piece of paper
3. Identifying SSxx ports only and exclude all HSxx and SSPx identifiers
- delete the above bootflags (a) and (b)
- add these boot flags
c. -uia_exclude_hs
d. -uia_exclude_ssp << no longer required as per 9 Nov 2018 latest commit
e. do not forget to include uia_include=HS09; HS10
- reboot and discover all SSxx ports using your USB 3.0 device like in the video link
4. Identifying SSPx ports only and exclude all HSxx and SSxx identifiers
- follow steps similar to above instruction set except you replace -uia_exclude_ssp with -uia_exclude_ss instead
5. Final Step
- Finally, with the ports you had discovered in steps 1, 2 and 3, you can now use the uia_include or uia_exclude boot flags for your discovered ports
a. in my build example, I prefer to use uia_exclude. So, the final boot argument will look like like this
uia_exclude=HS05;HS08;HS11;HS12;HS13;SS05;SS06 (all of these are my unused ports)
b. if one prefers to use uia_include boot argument, the final boot flag will look like this
uia_include=HS01;HS02;HS03;HS04;HS06;HS07;HS09;HS10;HS14;SS01;SS02;SS03;SS04 (all of these are the used ports discovered)
Donate
Gitter Chat
MSI B360 Gaming Arctic
[ref]onemanosx[/ref], Very Nice :guitar
[ref]MaLd0n[/ref], thank you! :guitar
Donate
Gitter Chat
I followed the vid and excluded 4 unused ports so I got all my mobo ports working with USB 2.0 in addition to x4 USB 3.0 which is more than enough.
But after long sleep/wake the USB 3.0 was ejected automatically, Im I doing something wrong, or it should be like this ?
Hack Pro: Asus Strix Z590i, i9-11900K, RX 6900 XT, 1TB Samsung QVO SSD, RAM 16GB Corsair RGB @3200Mhz (Big Sur) OC
Hackbook Pro: (MSI GE63 Raider RGB) i7-8750H, Intel UHD 630, GTX1070 8GB(disabled), 16GB RAM @2666Mhz (Big Sur) OC
Is your DSDT patched with the correct USB power properties?
Donate
Gitter Chat
Good guide. Thank you :D
You're welcome, hope it helps!
Donate
Gitter Chat
Working here, thank you, but I have only ONE usb3.0 port that isn't working as usb3.0 others are..
Thank You
3,7 GHz Intel Core i7
16 GB 2133 MHz DDR4
Radeon RX 580 4096 MB
[ref]dlhenke[/ref], I've a wavlink hub that didnt work as expected except for the card reader. No solution for me either. :bye
Donate
Gitter Chat
It is working now I've changed to another USB3 port.. but none of my USB3 devices is working on that usb3 port. :-(
16 GB 2133 MHz DDR4
Got everything fixed ..
boot arguments for my motherboard
uia_exclude=HS01;HS02;HS13;HS14;SS01;SS03;SS04;SS08;SS09;SS10;SS11;SS12;SS13;SS14;USR1;USR2
Just working everything even USB3.0 10ports ORICO with mix devices usb3/usb2 etc..
Many thanks to @MaldOn for enlightening .
16 GB 2133 MHz DDR4
I actually don't know, the DSDT was made by our super guy Mald0n and I have no enough knowledge to check it again to see if USB power properties are ok :?
Then I used Rehabman method to create USB ssdt along with USBInjectall.kext and removed the boot flags, it also worked but the problem is still there.
maybe you would like to share what was done wrong for other readers to take lesson from
Edit: I see you edit out your earlier post. So i gathered you had made a small error in not activating that one port causing your hub to only able to detect usb 2.0 devices only.
Added in 17 minutes 27 seconds:
flags
Is it a problem to only one port or all the ports?
Donate
Gitter Chat
As I tested the problem is with all free ports when I connect a USB 2.0 or 3.0 devices, they will be disconnect after sleep/wake.
But keyboard (HS05), mouse (HS07) and wifi card (HS10) have no problems at all.
I edited my previous post to add more information about what I did to be more clear :oops:
is a common problem in many cases, eject after sleep, now the error is back, apple change again :mrgreen:
apple change again
Damn you Apple!! :hammer:hammer:hammer:mrgreen:
Donate
Gitter Chat
Oh wow! again? At least now I know how to deal with it, thanks :D
Added in 50 seconds:
Damn you Apple!!
Haha :boxing
