XFX RX580 problem on instalation Mojave, restarting
Hello friends, I've been struggling around the installation for days.
I tried all the ways and reviewed all the tours, but I simply stuck it on each and every time.
I made a video to make it clearer to you.
https://youtu.be/Y7AqzOA3uyk
(I thought that Mojave has this problem, but here I have installed High Sierra, and I have the same problem as Mojave)
but here's a brief summary.
When I start installing with the graphics card XFX RX580, it simply will not start. is constantly restarted. Only when I get the graphic card out, everything is ok. I'm proceeding with the installation, and everything is great.
Can you help me? please..
first, never buy xfx for hacks, don't work good
try update clover bootloader in usb stick
Thanks for the reply. I'm gonna try a new clover. Which graphic would recommend me for the final cut. I can return this graphic and replace it for someone else. I've read that amd graphics cards are the best for the final cut, am i right?
Asus, Gigabyte, Power Color
use whatevergreen kext
