Hello members and team,
I am attempting to install High Sierra on my laptop but it got stuck onto the following step.
It goes through with the verbose mode, it then goes to the loading screen and after 1 minute the mouse comes up but no menu bar or anything else comes up.
I disabled Descrete graphics, Intel Virtualization an Legacy support from bios as those are the only options existion on my laptop model.
Do note that I am more on the noob side at hackintosh so extra instructions will be needed if you will ask me to provide files.
System config:
Lenovo Ideapad 510-15IKB
Intel i7-7500U Intel HD 620 Kaby Lake
Nvidia geforce 940mx
P. S: I am using the clover folder as instructed in the tutorial but there is no config2.plist to use (as discribed in the error section)
Regards,
Andrei
try with -x
Hi @MaLd0n,
I was too tired last night to write back.
I decided to try one more time and since I was tired already I started drifting the mouse left-right right after booting the installer. Guess what? It went to the choose language screen. Amazing! I leave it like that for a moment and again it freezes.
I decided to try again since that was progress. I started moving the mouse around and managed to install it succesfully...
Problem 2: after the whole setup finished the system looks good, no wifi since I didn't know what kext to use (yet), video works well without artefacts and audio works out of the box... But the laptop does not seem to cooperate well. I tried to copy the post install files and it barely moves. I do a copy paste and the file showed up on desktop after 2 minutes. (in case this is vital info, I installed it on an ssd).
Is that something to be fixed?
Thanks!
