Help !! ALC1150 no sound macOs Mojave
put ur GPU in first slot, ur gpu run in x4, need a x16
alc1150 need a codeccommander
Hello MaLd0n,
I'm in the same boat, no sound on ALC1150 (X79 Deluxe)
I tried all available layouts (1, 2, 3, 5, 7, 11) in Clover Configurator
I use AppleALC v1.3.7, and LiLu v1.3.5 is installed in the same /EFI/CLOVER/kexts/Other folder
Any help appreciated :)
[ref]noisegate[/ref], in some cases alc1150 need a codeccommander
[ref]noisegate[/ref], is common with alc1150, i edited codeccommander for alc1150, but i dont remember links, check if u found in search forum
[ref]MaLd0n[/ref], thanks bro, I've searched everywhere on Olarila/insanelymac forums and google, I can't find an edited version of codeccommander for alc1150. I must have missed it somehow, still no luck...
