Hi.
I'm on latest Mojave build with a Dell 3542 laptop.
Everything working as it should except one thing. Audio lost after waking from sleep.
Here are some observations :
1) Same thing happened with High Sierra , so it is not a system bug.
2) I'm using latest virtualsmc instead of fakesmc. I had the same problem with fakesmc , so the problem it is not there.
3) I'm not installing kexts on l/e but at clover/other , because I don't use fakesmc so if I choose inject=detect kexts will be loading from clover/other and from l/e , isn't that right ?
I thing the audio problem has to do with dsdt.aml or my config.plist.
Can someone check ?
Thanks in advance.
Send me Macbook-Pro-Dell.zip
u need edit a kext for ur codec :guitar
read link above, have all info there, u can search too, have a codeccommander edited for many codecs
