full solution u need post a full dump
with our app
RunMe.app
Thank you for base patches, will be investigating trackpad i2c and battery patches, anyway to patch DSDT to run without any clover patches? Want to run as close to a factory system as possible. Also do NOT want to disable nvidia, as the wiring on this system has nvidia GPU always dedicated to HDMI output, so macOS can actually us nvidia in this dual gpu setup but only from HDMI port.
just remove _dsm into nvidia device
