post a full dump
RunMe.app
10.13.4 don't have this problem, fixed
Thanx!
the problem is x79 chipset, have a several problem with sleep, if don't work, live with it
(11.32 KiB) Downloaded 1 time
Thank you very much, what's the difference between my and your DSDT
in my case can I convert kext to dsdt patches?
I need delete all 4 ssdt and change to your dsdt? in api > patched?
stay with DSDT.aml and SSDT-PM.aml
Unfortunately, the sleep still does not work, should I go back to my configuration? or leave yours?
use my DSDT, don't need ssdts, only for PM
extract new SEND_ME
try it
CLOVER.zip
have a some strange patches in config.plist
what happens?
what happens?
from what I remember these "strange" things are from firing a cpu, so it stands on the apple logo or I spit with errors kernel trap type 14
back to ur old folder with my dsdt + ssdt PM and delete _DSM to XDSM patch in Acpi tab, this patch kill all _DSM into bios
I restored my config before your changes and removed it ( _DSM to XDSM patch in Acpi tab ) and work, thats is good?
ye, now extract new SEND_ME, i need check
sleep in x79 is very rare work, i just apply a correct imei in last dsdt, live without sleep in x79 :guitar
will I be able to install Mojave on the same settings?
So that's all the stuff from my poor hp?
Yes, same files work for Mojave ;) go to beta 10
Yes, same files work for Mojave go to beta 10
I will wait for a stable version :D
can you write what changes you made in my all files / config?
-FIX ERRORS AND WARNINGS
-FIX ACPI ERRORS
-REMOVE UNUSED DEVICES
-HPET
-SATA
-DMAC
-SLPB
-HDEF
-RTC
-IRQs
-SBUS
-MIKEY
-BUS1
-MCHC
-ALS0
-SHUTDOWN
-LAN
-IMEI
-EC
-PNLF
-FULL RENAMED DEVICES
