daraco Posted September 10, 2018 Posted September 10, 2018 Hi there, Ive followed this guide: https://www.insanelymac.com/forum/topic/334899-intel-framebuffer-patching-using-whatevergreen/?page=1 And cannot install the graphics card properly. It shows 7mb..any suggestions pls? Ive attached the send me file here and in the DSDT patch forum..just in case Thanks DSDT for MSI laptop - send me.zip
Administrators MaLd0n Posted September 10, 2018 Administrators Posted September 10, 2018 DSDT.aml.zip u need check here https://www.insanelymac.com/forum/topic/335018-release-intel-fb-patcher-v133/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
daraco Posted September 10, 2018 Author Posted September 10, 2018 (edited) Thanks [ref]MaLd0n[/ref], Man, muito obrigado!!! The UHD graphics is working but the screen goes black on the second reboot any idea why? backlight? thanks Edited September 10, 2018 by Guest
daraco Posted September 10, 2018 Author Posted September 10, 2018 Audio and PCI - hdmi & Mini-DisplayPort - not working any suggesttions pls?
Administrators MaLd0n Posted September 10, 2018 Administrators Posted September 10, 2018 post a full dump RunMe.app -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
daraco Posted September 11, 2018 Author Posted September 11, 2018 Thanks [ref]MaLd0n[/ref], I've attached the file. The UHD630 worked on the first boot but then it stopped. I am booting from a USB. Should I use macBoook Pro 14 or 15? Valeu sendMe-msi-laptop.zip
Administrators MaLd0n Posted September 11, 2018 Administrators Posted September 11, 2018 DSDT.aml.zip Added in 27 seconds: audio and video, u need check, brightness i think in PNLF in clover config.plist work -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
daraco Posted September 11, 2018 Author Posted September 11, 2018 got this error, it is attached. hope u can help. thanks
Administrators MaLd0n Posted September 11, 2018 Administrators Posted September 11, 2018 U use a fakesmc or virtualsmc? DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
daraco Posted September 12, 2018 Author Posted September 12, 2018 using virtualsmc....Should I try fakesmc instead? Thanks for ur help [ref]MaLd0n[/ref],
daraco Posted September 12, 2018 Author Posted September 12, 2018 I got a brand new fakesmc and it has improved But still no HDMI or Sound. Should I try FakePCIID_Intel_HD_Graphics.kext or some other kext? thanks
daraco Posted September 12, 2018 Author Posted September 12, 2018 Hi [ref]MaLd0n[/ref], Thanks so much for ur help so far, I've tried top add the following kext: FakePCIID_Intel_HD_Graphics.kextFakePCIID_Intel_HDMI_Audio.kextFakePCIID.kext Used kext utility and also added on USB that is booting the laptop. I've attached my config.plist files - the copy one is my backup - they have different setups from FB intel patcher Thanks Added in 41 minutes 41 seconds: I've seen that Support started with macOS 10.13.6 (17G2112) / 10.14 beta 4 (18A336e) and the image that I've downloaded from here is 10.13.6 17G2208 8th Intel Processors. Could that be the issue? config-files.zip
Administrators MaLd0n Posted September 12, 2018 Administrators Posted September 12, 2018 ye, i think u need as last update for coffeelake -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
daraco Posted September 17, 2018 Author Posted September 17, 2018 Fala [ref]MaLd0n[/ref], I am trying to use Mojave to see if it accepts my GPU but im currently getting this panic on Restart or shutdown. Can you help pls? Thanks
Administrators MaLd0n Posted September 17, 2018 Administrators Posted September 17, 2018 sound like a lilu or applealc or other third party kext -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
daraco Posted September 19, 2018 Author Posted September 19, 2018 Fala [ref]MaLd0n[/ref], Blz?!?! UPDATE: What works: USB 2 and 3 Ethernet w/ cable UHD Graphics 630 (Coffee Lake) w/ framebuffer - 15360mb Battery - Shows percentage Memory shows 16GB What I think is working: Processor shows core i7 2.21ghz, 6 cores, L2 Cache 256 kb and L3 Cache 9 MB - Is it right? What doesn't work :thumbdown HDMI & Mini-DisplayPort Audio Camera WiFi (I think it wont work cos its intel, right?) ISSUE 1: The HDMI was only detected when I installed Nvidia GTX 1060 via command line (https://github.com/Benjamin-Dobell/nvidia-update). But didn't show anything on the second screen. I've used Intel FB-Patcher v1.4.0 which patched framebuffer and also fixed IOUSBHostHIDDevice compliance violation wLength data.As shown in the attached image. I have used FakePCIID and FakePCIID_Intel_HD_Graphics via usb on Clover but HDMI did not work. Should I install it via Kext utility too? Have anyone made HDMI & Mini-DisplayPort work? ISSUE 2: The screen is black during boot, then I enter my password while its black, then after a while the screen works - It seems like the screen is warming up - Tried to SSDT-PNFL.aml and add the following KextsToPatch: Comment change F%uT%04x to F%uTxxxx in AppleBacklightInjector.kext (credit RehabMan) Name com.apple.driver.AppleBacklight Find RiV1VCUwNHgA Replace RiV1VHh4eHgA Then I used "sudo kextcache -i /" to apply it and also tried repair permission command. I also tried add intelBacklight.kext via kext utilty and did not work. Any suggestions pls? ISSUE 3: The system got a NEW panic once I try to shutdown or restart. See image attached pls: Any leads? Ja to 2 semanas nessa novela , sera q consigo nesse laptop? T pago mais umas assim q termina essa novela Valeu Bro!
Administrators MaLd0n Posted September 19, 2018 Administrators Posted September 19, 2018 if u have a notebook with optimus technology, u need disable nvidia and use intelHD -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
daraco Posted September 20, 2018 Author Posted September 20, 2018 Hi [ref]MaLd0n[/ref], I have disable the nvidia on windows to make sure which graphics device is connected to the HDMI. And the second screen connected via the HDMI stopped working at all. So I guess the HDMI is connected to the Nvidia. It won't work right? I need multiple monitors, so i guess I have 2 options: 1 - Can I make Nvidia gtx1060 w/ optimus technology work on Mojave? Don't need be 100% 2 - Get a USB hub w/ a HDMI port - Would that work? Any other suggestion? Valeu Bro!
daraco Posted September 21, 2018 Author Posted September 21, 2018 Hi [ref]MaLd0n[/ref], After 2 weeks of trial and error MSI GV622 8RE - dual screen - UHD630 1536mb - nvidia gtx1060 ONLY 256mb - Almost there!!! Gonna try triple screen soon and also on a curved monitor 35" Also Mojave as soon it comes out!! How do I fix the 256mb to 6gb? valeu bro
daraco Posted September 25, 2018 Author Posted September 25, 2018 ola [ref]MaLd0n[/ref], tudo bem? To tentando o som, o minha placa e de e audio ALC892. Aparece os output & input mas nao tem som. Muda ate pra Headphone quando insert, e tbm funciona como microphone quando coloco no buraco do mic Mas nao sai som nesse caralho.... Sabe como arruma isso? Valeu
Administrators MaLd0n Posted September 25, 2018 Administrators Posted September 25, 2018 dá uma sacada aqui "> se applealc não funcionar, use o AppleHdaPatcher https://Olarila.com/forum/viewtopic.php?f=81&t=6528 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
daraco Posted September 25, 2018 Author Posted September 25, 2018 it worked w/ voodooHDA - Added in 54 seconds: it worked w/ voodooHDA
anildooo Posted April 4, 2019 Posted April 4, 2019 ISSUE 3: The system got a NEW panic once I try to shutdown or restart. See image attached pls: [The extension jpg has been deactivated and can no longer be displayed.] Any leads? Ola Daraco. Voce consigiu resolver ou panic attack on shutdown/reboot. Eu tambe tenho a mesma problema. Eu tambe nao esta consigir ligar com HDMI. Axo que meu HDMI tambe e ligado no Nvidia. Please help me if you have a solution. Meu laptop e um MSI GF63 8RC
Administrators MaLd0n Posted April 4, 2019 Administrators Posted April 4, 2019 [ref]anildooo[/ref], --Run_Me RunMe.app "> -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
