v.osypets Posted July 19, 2018 Posted July 19, 2018 Hello! Sometimes my monitor LG LG 31MU97Z-B won't wake after sleep. If i push power button on monitor for 1sec it's wakes. On Whatevergreen kext FAQ I found possible resolution for this issue - https://github.com/acidanthera/WhateverGreen/blob/master/Manual/FAQ.Radeon.en.md. Why can a highres DisplayPort-connected display fail to wake (e.g. some LG 4K models)?Sometimes AGDC configuration preference could be the case. For 4K and lower it makes sense to try disabling it by passing CFG,CFG_USE_AGDC — False (00) via SSDT or similar. Is there someone facing already with that problem and can help with it? My hardware is: CPU: Intel 8700K GPU: integrated MB: MSI z370m Gaming Pro AC RAM: 16GB Monitor: LG 31MU97Z-B My clover folder also attached. thanks! CLOVER.zip
Administrators MaLd0n Posted July 19, 2018 Administrators Posted July 19, 2018 Is there someone facing already with that problem and can help with it? My hardware is: CPU: Intel 8700K GPU: integrated MB: MSI z370m Gaming Pro AC RAM: 16GB Monitor: LG 31MU97Z-B My clover folder also attached. post a full dump RunMe.app -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
v.osypets Posted July 19, 2018 Author Posted July 19, 2018 post a full dump RunMe.app Here it's Send me vohack.zip
Administrators MaLd0n Posted July 19, 2018 Administrators Posted July 19, 2018 Here it's replace, reboot and new send_me with new folder, very wrong config, we try CLOVER.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
v.osypets Posted July 19, 2018 Author Posted July 19, 2018 (edited) replace, reboot and new send_me with new folder, very wrong config, we try here is new debug. Send me vohack.zip Edited July 19, 2018 by Guest
Administrators MaLd0n Posted July 19, 2018 Administrators Posted July 19, 2018 here is new debug. looks good test all -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
v.osypets Posted July 19, 2018 Author Posted July 19, 2018 looks good test all Now monitor permanently sleeping after system wake. And only pushing power button on monitor helps it to wake up.
Administrators MaLd0n Posted July 19, 2018 Administrators Posted July 19, 2018 Now monitor permanently sleeping after system wake. And only pushing power button on monitor helps it to wake up. bt u have a full wake? work? in see ur desktop? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
v.osypets Posted July 19, 2018 Author Posted July 19, 2018 bt u have a full wake? work? in see ur desktop? System is wakes, but monitor sleeping and only pushing power button (menu button) on monitor helps it to show image (login screen). Something in system not sending right wake signal to the monitor...
Administrators MaLd0n Posted July 19, 2018 Administrators Posted July 19, 2018 put in clover/acpi/patched SSDT TEST.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
v.osypets Posted July 19, 2018 Author Posted July 19, 2018 put in clover/acpi/patched SSDT TEST.aml.zip now monitor sometimes wakes up and sometimes no, like on my old config.
v.osypets Posted July 22, 2018 Author Posted July 22, 2018 replace, reboot and new send_me with new folder, very wrong config, we try Can you explain in more details why is my config wrong? DSDT? Clover? Thanks!
v.osypets Posted August 7, 2018 Author Posted August 7, 2018 One more interesting thing - when system wakes up by pushing power button on PC (case), monitor wakes normally.
Administrators MaLd0n Posted August 7, 2018 Administrators Posted August 7, 2018 One more interesting thing - when system wakes up by pushing power button on PC (case), monitor wakes normally. use only power button, i kill other devices for wake, have only two, XHC and Power Button -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
v.osypets Posted August 7, 2018 Author Posted August 7, 2018 use only power button, i kill other devices for wake, have only two, XHC and Power Button How to do that in more proper way in DSDT?
Administrators MaLd0n Posted August 7, 2018 Administrators Posted August 7, 2018 just remove _prw -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
v.osypets Posted August 7, 2018 Author Posted August 7, 2018 just remove _prw All _PRW methods in all scopes and etc?
v.osypets Posted August 7, 2018 Author Posted August 7, 2018 Oh, sorry I understand. I need to remove this method on devices that causes wake reason. Thank you
Administrators MaLd0n Posted August 7, 2018 Administrators Posted August 7, 2018 u can remove in specifc method, device, scope, i like remove all and put one in xhc for wake in keyboard/mouse -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
v.osypets Posted August 7, 2018 Author Posted August 7, 2018 u can remove in specifc method, device, scope, i like remove all and put one in xhc for wake in keyboard/mouse In my case waking up with keyboard and mouse not always brings display to wake up. And I need to push monitors power button to wake it up. But earlier it was ok. But when I'm pushing power button on case, monitor wakes normally. Strange thing...
Administrators MaLd0n Posted August 7, 2018 Administrators Posted August 7, 2018 use only power button and remove _prw from xhc device some LG 4k have it -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
v.osypets Posted August 8, 2018 Author Posted August 8, 2018 use only power button and remove _prw from xhc device some LG 4k have it But I think it's not monitor problem. If I push button on mouse my PC wakes in two stages (please see screenshot) - DarkWare from Normal Sleep and after DarkWake to FullWake from normal sleep. If I pushing power button on case we have wake in one stage - Wake from Normal Sleep. Is there possible to program wake with mouse and keyboard same as with power button?
Administrators MaLd0n Posted August 8, 2018 Administrators Posted August 8, 2018 kill all devices wake, use only power button disable hibernate too https://Olarila.com/files/Utils/disablehibernate.command.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
v.osypets Posted August 8, 2018 Author Posted August 8, 2018 kill all devices wake, use only power button There is no way to change wake conditions for keyboard and mouse?
Administrators MaLd0n Posted August 8, 2018 Administrators Posted August 8, 2018 There is no way to change wake conditions for keyboard and mouse? idk -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
