LO1410 Posted July 17, 2018 Author Posted July 17, 2018 k Again I tried EVERYTHING ... clean installation, changes in the BIOS ... however, I always received the same screen with the message ... I do not know what to do or what the problem is, if my graphics card is incompatible. .. or what, what remedy, I will have to remove the graphics card to my PC to use Mac, thanks for all the help you have given me. For real. But one last thing ... now that I'm going to use Intel's integrated graphics, do I need to change the CLOVER folder and the DSDT that you made me, or can I use the same folder? Thanks
Administrators MaLd0n Posted July 17, 2018 Administrators Posted July 17, 2018 But one last thing ... now that I'm going to use Intel's integrated graphics, do I need to change the CLOVER folder and the DSDT that you made me, or can I use the same folder? Thanks use same files and injectIntel -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
LO1410 Posted July 17, 2018 Author Posted July 17, 2018 use same files and injectIntel Now all right, I have my native resolution ... Intel hd graphics ... all right, but when I passed the CLOVER folder that you gave me, and restart the PC, when logging in and put my password, the keyboard and the mouse do not work, oh ... god, if it's not a problem, it's another, what patience ...
Administrators MaLd0n Posted July 17, 2018 Administrators Posted July 17, 2018 run app and post one new dump here with clover folder -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
LO1410 Posted July 17, 2018 Author Posted July 17, 2018 run app and post one new dump here with clover folder Attached files. Now the audio on board does not work either, only the audio works through the HDMI port of the motherboard, the other native jack ports of the board, nor recognizes them, and the only way to use the PC was to eliminate the DSDT.aml of the folder. Send me Fox's iMac .zip
Administrators MaLd0n Posted July 17, 2018 Administrators Posted July 17, 2018 u need use my clover folder, i'll check what wrong -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
LO1410 Posted July 18, 2018 Author Posted July 18, 2018 u need use my clover folder, i'll check what wrong I have used the Clover folder that you have given me, but when it asks for the password in the login, it does not detect me neither the mouse nor the keyboard, but if I remove the file dsdt.aml, and restart, now yes detects me the peripherals .. And as I said, it does not eject audio through the ports on the motherboard, it just ejects audio through the HDMI port on the board.
Administrators MaLd0n Posted July 18, 2018 Administrators Posted July 18, 2018 CLOVER.zip USE it, let me know, new SEND_ME after reboot -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
LO1410 Posted July 18, 2018 Author Posted July 18, 2018 USE it, let me know, new SEND_ME after reboot Thank you very much for your patience and help during the entire procedure, Mr. MaLd0n. I replaced the complete folder I had with the one you gave me, I restarted and immediately everything was fine, peripherals like the keyboard and mouse worked, and also the native audio of the motherboard ... BUT now I ran out of audio through the port HDMI on the motherboard, and before it worked properly. But everything else works perfectly. I also restarted and made a new dump, as you told me, attached files. Send me Fox's iMac.zip
