Cassio Posted October 23, 2011 Posted October 23, 2011 Rode os seguintes comandos no terminal sudo perl -pi -e 's|\xeb\xa8\x83\xf8\x02\x7c\x15|\xeb\xa8\x83\xf8\x03\x7c\x15|g' /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver sudo perl -pi -e 's|\x78\xe8\x83\xf8\x02\x7c\x11|\x78\xe8\x83\xf8\x03\x7c\x11|g' /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver Fonte: http://netkas.org/?p=794 Apenas para GF110 (CC/SM 2.1+) sudo perl -pi -e 's|\x8B\x87\x1C\x0C\x00\x00\x89\x06\x8B\x87\x20\x0C\x00\x00\x89\x02|\x31\xC0\xFF\xC0\xFF\xC0\x89\x06\x31\xC0\x89\x02\x90\x90\x90\x90|g' /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib Fonte: http://www.insanelymac.com/forum/index.php?showtopic=266318 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Jahworks Posted June 14, 2012 Posted June 14, 2012 Após rodar até o patch apareceu esse erro no luxmark: RUNTIME ERROR: No OpenCL device selected or available GTX 560M GF116. ----------- Tem alguma outra maneira de instalar o patch?! Não estou conseguindo instalar o Cuda. Estou usando o MP DP4. ASUS G75VW-RS72 • CPU: Intel Core i7- 3610QM 2.29GHz • RAM: 12 GB DDR 3 ELPIDA • HD: 240GB CORSAIR GS SSD (MAC OS) HD 2 750GB (Win 8) • GPU: GeForce GTX 670M 3GB 1920x1080 • OS: Mac OS X 10.10. (14A389) • BIOS: 223.
iHackintosh_PT Posted June 14, 2012 Posted June 14, 2012 Oldnapalm, testei aqui no 10.8 DP 4,funcionou.... boa Asus P7H55M PRO Core i7 2.81 GHz RAM 8 GB 1333 MHz DDR3 AMD 6990 Dual GPU 4 GB DDR5 OS X 10.10.3 Toshiba TV 42* 1920x1080 Samsung SyncMaster 22* 1920x1080 Apple Cinema Display 20ª
Jahworks Posted June 18, 2012 Posted June 18, 2012 Boas noticias. usando os drivers para o 10.7.3 PARA A GTX 560M 3GB GDDR5 http://www.osx86.net/view/2074-gtx_5xx_enabler.html apliquei o patch: sudo perl -pi -e 's|\x8B\x87\x1C\x0C\x00\x00\x89\x06\x8B\x87\x20\x0C\x00\x00\x89\x02|\x31\xC0\xFF\xC0\xFF\xC0\x89\x06\x31\xC0\x89\x02\x90\x90\x90\x90|g' /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib OBTENDO: OPENCL - usando SMBIOS MacBookPro8,2 e legacyAGPM: http://cl.ly/HhsQ http://cl.ly/HiSS UHUU! SÓ PRECISA MELHORAR O DESEMPENHO DO OPENGL. ALGUEM SABE COMO FAÇO? ASUS G75VW-RS72 • CPU: Intel Core i7- 3610QM 2.29GHz • RAM: 12 GB DDR 3 ELPIDA • HD: 240GB CORSAIR GS SSD (MAC OS) HD 2 750GB (Win 8) • GPU: GeForce GTX 670M 3GB 1920x1080 • OS: Mac OS X 10.10. (14A389) • BIOS: 223.
