maybe java version u are using...
Running OK
java version "1.7.0_21"
Java SE Runtime Environment (build 1.7.0_21-b11)
Java HotSpot 64-Bit Server VM (build 23.21-b01, mixed mode)
Win7 Pro x64 SP1
Also:
Thanks for the Mac version too - my hackintosh 10.8.3 using Creative Audigy 2 card for audio out
(1) I would need (Mavericks) Kext for the following:
04:00.0 USB controller: NEC Corporation uPD720200 USB 3.0 Host Controller (rev 04) (prog-if 30 [XHCI])
Found: "net.osx86.kexts.GenericUSBXHCI" that includes the Device, however the Download butten is grayed out, can't download it.
 00:1b.0 Audio device: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller (rev 05)
       Subsystem: Dell Device 04b6
Found more Kexts, but none available to Download.
(2) Also searching for:
03:00.0 Network controller: Intel Corporation Centrino Wireless-N 1030 [Rainbow Peak] (rev 34)
01:00.0 VGA compatible controller: NVIDIA Corporation GF108M [GeForce GT 525M] (rev a1) (prog-if 00 [VGA controller])
Thanks!
1 - http://www.insanelymac.com/forum/topic/286860-genericusbxhci-usb-30-driver-for-os-x-with-source/
2 - about audio u should read a lot ...
3 - wireless not compatible .. never works
4 - the nvida don't work .. optimus don't work in mac os x .. only the intel hd 3000
1 advice .. is not only find kext to things work in mac os x.. u should read .. and googling to try to find solutions.. u have a pc .. not a mac..
Hello!
If the card is a traditional "half of size" and you use the bluetooth, you can change to AR9285 (with Bluetooth) The card is "configurable" to OS X, not works native, but works with configuration in Atheros family kext..
The AR9280 "half of size" work native, but, don't have bluetooth.
...also, you can try a USB option, as Realtek Wi-Fi
Sounds good @Jucelio - thanks!
I'll consider to give it a go with this option.
Based on the downloads page, it does not supportes 10.9 Mavericks though.
Are there any compatbile wlan cards perhaps too?
Hello! The Realtek 10.8 drivers works with mavericks!
I Have a usb adaptador (RTL8191SU) and the 10.8 driver works normally!
...and, the other option, you can change your wireless adaptor, if your machine use the type "mini-pci half" for mentioned models...
In this option, i prefer the AR9280!
Good luck.
Sounds good. I currently have an i5 6500 non-k which I do want to upgrade soon to something meatier and a fancier MB. That said I also have a GTX 970 and would like to upgrade that to a 1080TI so not sure I can justify doing both. If I did do both through I pretty much have a second system as I upgraded my case and a few other parts a while back, so selling the second system could cover some of the cost.
