Updated:
DPCIManager
New app developed by phpdev32.
Hello, I'm releasing the System Info app, developed by me based on oldnapalm's idea. It has two main uses, first as a hardware parser, as in this image:
And second, linking devices to its related kext, as shown below:
The application goal is, beyound helping the user to identify hardware, to generate a Hardware Compatibility List, which browser is available at http://Olarila.com/kexts. The user can send kext information (name and version) and respective device ids to feed the system from inside the application, selecting the menu option "Submit data", as in the image:
I hope you find the software useful and help us back providing data to the HCL.
Download: SystemInfo.zip
Windows and Linux versions allow users to evaluate the hardware compatibility. Requires java JRE to run.
Windows: SystemInfoWin.zip
Linux: SystemInfo.tar.gz
I got a problem ,
when I put the Ven ID and Dev ID and Click search button ,
then It's just showed nothing ,
But I used the System Info First,
It's showed my devices have kext.
what's problem with it??
You have to type vendor or device ID (not both) and select the right option in the combo box below.
You can download only if the button is enabled. If it's disabled the kext is not available for download, only the information for compatibility check is available.
i got a problem in this computer it can't open the file
with java and java is correctly instaled, what can i do
laptop compal hel 80 c * nvidia ge force go 7600 * audio alc 883 not completly ok * intel core 2 duo t 5600 1.8
with all problems but runnin good THANKS TO ALL COMUNITY
Which Java version and which OS?
Run from terminal (java -jar) and post the error message.
with windows 7 x 86 last version of java
cause i go to page to get it and it sais that i have the lastest
thanks, u guis do wonderfull work
with all the issues but life with no issues has no fun
Right click on the jar and choose to open with Java Runtime, maybe the jar extension is associated with another app.
For portuguese discussion http://Olarila.com/forum/viewtopic.php?f=6&t=25
hello again
in the system info is shown a number of kexts that are associated to those devices, do i have to have those kexts instaled
732916216_Screenshot2012-02-28at4_29_15PM.thumb.png.cb61016894c14183ecb44633b9a099e1.png
all this because my audio doesnt play ok with all kexts what was good for me is a thing likae a compilation off azalia and applehda, because whene in azalia it appears to have hda, never tested but from headphones the audio is ok
but to have speakers i use alc883 from the hazard dvd, but in this case the hdaudio output doesn't work or i cant control volume and it doesn't play in the headphones
another issue is that the phones and speakers don't change automatic when plug in input jack non even when using voodoohda, that doesn't give proper sound but assigns 3 channels independently, i lerned when using traktor that i can have sound in speakers and phones at the same time in this program if i put one music to play in speakers--- master out and pfl/cue---monitor out send to headphones, and headphones when plugged speakers shut down, the problem with voodoo is that the sond doesn't stay in 44100 it changes and don't change chanels automatic
can i resolve this
THANKS IN ADVANCE GRAT JOB
Can not run System Info.app on Mac OS X 10.8 (http://Olarila.com/forum/viewtopic.php?f=27&t=1627). JavaSE Runtime 7u7 is installed. But when I try to open System Info, it again asks for JavaSE 6 Runtime. When I try to open Java Control Panel, it throws me error "Java Control Panel quit unexpectedly while using the libjvm.dylib plug-in. I am not sure whether this is right place to post this issue or not.
Sony Vaio SVE14A15FNB
Intel Core i5-2450M (Sandy Bridge)
AMD Radeon HD 7650M | Intel HD 3000
Intel HD Audio | Intel® Centrino® Wireless-N 2230 (WiFi + Bluetooth 4.0)
Intel USB 3.0 eXtensible Host Controller
Edit. all is working now...
mouse is no smooth is there any fix...???
Processor: intel i5 6600k
Mobo: Asus Z170 Pro Gaming
Ram: GSKILL 2133mhz DDR4 2x4GB
GPU: Asus Strix Gtx 970 4gb
thx for the nice app :)
maybe a suggestion, we submitting al the info and all the kext files right ?
maybe a download button wil be great so we don't need to look for kext files as they are stored in one place
would make thing more easy for some people ;)
just like osx86 tools do back in the old days aka Leopart
Gr Pieter
Just exactly how does this tool work? I'm currently using it on Windows 7. I clicked on File > Check compatibility then File > Export devices. Does it want me to save something? Where? What extension? Does this activate hardware properly once in Mac OS?
no it's like the name say system info
gives u info about u system, to google for the right kext.
mac os x is for mac
hackmac os x is 99% of reading, googling, persistency and 1% of luck u hardware is compatible
if u want something to do u job... is not that
Hi, I am using Win 8 Pro 64 bit with JDK 7u7, Once I open System Info with CMD it will show up with the following error message
any help?
any help?
i have exactly the same difficulties. Anyone with some help?
maybe java version u are using...
Running OK
java version "1.7.0_21"
Java SE Runtime Environment (build 1.7.0_21-b11)
Java HotSpot 64-Bit Server VM (build 23.21-b01, mixed mode)
Win7 Pro x64 SP1
Also:
Thanks for the Mac version too - my hackintosh 10.8.3 using Creative Audigy 2 card for audio out
