Aditya Nugraha Posted May 26, 2020 Posted May 26, 2020 I am receiving this.. Mac Os Application is damaged.. is this normal?
Administrators MaLd0n Posted May 26, 2020 Author Administrators Posted May 26, 2020 4 hours ago, Aditya Nugraha said: I am receiving this.. Mac Os Application is damaged.. is this normal? no i need update images -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Bimmer Werke Posted June 29, 2020 Posted June 29, 2020 (edited) On 1/1/2020 at 12:06 PM, rositaott said: [ref]MaLd0n[/ref], Download completed twice but stil getting the same error; I got this error. Solution (no need to re-download, nothing wrong with the installation file): 1. turn off network connection,e.g. wifi (top right installation nav bar/menu) or network card (right click network icon in bottom guest window) or whatever to disconnect your network e.g. cut the cable etc 2. change date backward from terminal in the installation, top sub-menu terminal. e.g date 0512122316 for May 12 12:23 2016. If you did not disconnect the network in step 1, the date will immediately back to current date right after you close the terminal. The date will automatically updated when installation success and connected to network. It's work for me Thanks to @MaLd0n for the great works I plan to native install to my Asus Z8NA-D6 Dual Xeon L5640 12 cores 24 thread, is it possible? Edited June 29, 2020 by Bimmer Werke forgot to put smiley and say thanks
Administrators MaLd0n Posted June 29, 2020 Author Administrators Posted June 29, 2020 1 hour ago, Bimmer Werke said: Solution (no need to re-download, nothing wrong with the installation file): 1. turn off network connection,e.g. wifi (top right installation nav bar/menu) or network card (right click network icon in bottom guest window) or whatever to disconnect your network e.g. cut the cable etc 2. change date backward from terminal in the installation, top sub-menu terminal. e.g date 0512122316 for May 12 12:23 2016. If you did not disconnect the network in step 1, the date will immediately back to current date right after you close the terminal. The date will automatically updated when installation success and connected to network. It's work for me yes good job -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Cuandur Posted July 30, 2020 Posted July 30, 2020 Hi, I'm having problems downloading the any of the ISO's. I'm trying to get the Mountain Lion VM ISO, but when I select the link "Download Mountain Lion VM Olarila" from the post, it takes me to: https://drive.google.com/file/d/119XPfvqiVKXXHCRs8lDr601sasaGIfbZ/view?usp=sharing and I click the "download" button which takes me to: https://drive.google.com/uc?id=119XPfvqiVKXXHCRs8lDr601sasaGIfbZ&export=download and reports a problem: "Sorry, you can't view or download this file at this time. Too many users have viewed or downloaded this file recently. Please try accessing the file again later. If the file that you are trying to access is particularly large or is shared with many people, it may take up to 24 hours to be able to view or download the file. If you still can't access a file after 24 hours, contact your domain administrator." Can anyone help me download the ISO files please :)
Administrators MaLd0n Posted July 31, 2020 Author Administrators Posted July 31, 2020 9 hours ago, Cuandur said: Can anyone help me download the ISO files please copy to ur Drive and download -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
pwcomp Posted September 18, 2020 Posted September 18, 2020 when i extract the bz2 file it extracts to give me a raw file? which is not recognized in virtual box? i tried to just rename the extension to ISO but it failed to run?
Administrators MaLd0n Posted September 18, 2020 Author Administrators Posted September 18, 2020 no. is a iso raw is for hackintosh, renamed .dmg to .raw only -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
pwcomp Posted September 20, 2020 Posted September 20, 2020 (edited) On 9/18/2020 at 5:06 PM, MaLd0n said: no. is a iso raw is for hackintosh, renamed .dmg to .raw only so do i just rename it to .iso or .dmg for PC? Hi I seem to have come to a dead halt on the installation, all seemed ok on set up but it stops with the following screen https://www.dropbox.com/s/7q4d8i1dkyvkz1t/VirtualBox_Mac_20_09_2020_12_38_23.png?dl=0 Edited September 20, 2020 by pwcomp additional
Administrators MaLd0n Posted September 20, 2020 Author Administrators Posted September 20, 2020 1 hour ago, pwcomp said: https://www.dropbox.com/s/7q4d8i1dkyvkz1t/VirtualBox_Mac_20_09_2020_12_38_23.png?dl=0 need check if vbox have several updates. i don't use it for many time -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
pwcomp Posted September 20, 2020 Posted September 20, 2020 19 minutes ago, MaLd0n said: need check if vbox have several updates. i don't use it for many time yea I'm all up to date here:-)
Gustavo Costa Posted December 5, 2020 Posted December 5, 2020 Hello @MaLd0n! I followed the guide of the first page, but I was using Olarila Big Sur from Then I am stuck at: https://imgur.com/LLIBWnY. I use Linux. I use the CPU AMD Ryzen 7 2700X and the video card AMD Radedon RX 5700RXT, recommended by the OpenCore developers.
Administrators MaLd0n Posted December 5, 2020 Author Administrators Posted December 5, 2020 1 hour ago, Gustavo Costa said: Hello @MaLd0n! u need update things. i dont use it for long time -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
oldman20 Posted December 13, 2020 Posted December 13, 2020 Many thank Dell Inspiron 3558 (UEFI) - Intel Core i5 (5th Gen) 5200U /2.20GHz - 8GB RAM DDR3L - Intel(R) HD Graphics 5500/ nVIDIA GeForce 920M - 1366x768 - Realtek ALC255/ALC3234 @ Intel Wildcat Point-LP PCH - High Definition Audio Controller [F0]/ layout-id=20 - Intel(R) Dual Band Wireless-AC 3160 - Dell Touchpad /Synaptics I2C- Samsung SSD 860 EVO MZ-76E250BW 250GB (GPT)
Administrators MaLd0n Posted December 14, 2020 Author Administrators Posted December 14, 2020 Enjoy! -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
aikusy Posted April 14, 2022 Posted April 14, 2022 What are the virtual box commands for Monterey? I'm getting failed to query SMC handle error.
Desert Cheetah Posted April 24, 2023 Posted April 24, 2023 Hi, I'm trying to run Olarila Ventura on VirtualBox but I get stuck on this So can you help ?
nicovon Posted February 28, 2025 Posted February 28, 2025 Hi, is it possible to update this guide? Oracle VirtalBox is a little different. I'm trying to install macOS Monterey 12.7.4_21H1123
