Anyone using a coffee maker photo as a desktop wallpaper on their Hackintosh?
I'm redoing the desktop on my Hackintosh and want something calmer than the abstract gradients I've been cycling through. Boston winters keep me indoors a lot, so a warm kitchen scene with a coffee maker on the counter sounds like a nice fit for a secondary display that mostly shows widgets and a clock.
What I'm unsure about is resolution and scaling. My main monitor is 1440p and the side one is 1080p, so a single image stretched across both would look off. Should I pick one wallpaper that works at both sizes, or run two different images per display? I also worry a bright photo will wash out menu bar icons in light mode and make text harder to read in dark mode.
For those who use photo-style wallpapers, how do you handle the mismatch and keep icons readable? And where do you usually find high-resolution coffee-themed images that are free to use?
