My spec:
Acer aspire E1472G
Intel Haswell Core i54200U
8gb RAM DDR3L
OS: Macos 10.13
 Well i tried to boot Olarila High sierra but after installer succeeded, i hit a snag. After installation, i just booted like anyone usual but i hit Unsupported CPU And PCH. And it ends at a rebooted back to olarila bootloader because it told that it was a panic. I did a plist modification on another computer, and same thing twice, so has anyone dealt with this too? Give me a little solution ;)
Go to Monterey and use our efi folder haswell mobile
I cannot specify which efi folder was i5-4200U (Haswell Mobile)? Cause I am finding the efi in the efi folder page and no mentions for Acer Aspire E1-472G
You don’t need an EFI named for the exact Acer model. The Haswell mobile folder is selected by CPU/platform, so the i5-4200U falls under that folder; model-specific entries for an E1-472G usually won’t exist. If you’re following MaLd0n’s Monterey suggestion, that same Haswell mobile folder is the starting point, then adjust the plist for your graphics/audio and use a matching Haswell mobile SMBIOS. Keep the same EFI for installer and post-install boot.
