Hello all bro, I try to dump DSDT by press F4 in GUI Clover boot loader, then compile it returns me 2 boring errors that I can't fix.
Is there someone who can help me?
Code I using to dump:
./iasl -da -dl *.aml
result:
Intel ACPI Component Architecture
ASL+ Optimizing Compiler version 20161210-64(RM)
Copyright (c) 2000 - 2016 Intel Corporation
Input file DSDT.aml, Length 0x16F4C (94028) bytes
ACPI: DSDT 0x0000000000000000 016F4C (v02 DELL   WN09     01072009 INTL 20120913)
Pass 1 parse of [DSDT]
Pass 2 parse of [DSDT]
Parsing Deferred Opcodes (Methods/Buffers/Packages/Regions)
Parsing completed
Found 18 external control methods, reparsing with new information
Parsing completed
Disassembly completed
ASL Output:    DSDT.dsl - 753158 bytes
iASL Warning: There were 18 external control methods found during
disassembly, but only 0 were resolved (18 unresolved). Additional
ACPI tables may be required to properly disassemble the code. This
resulting disassembler output file may not compile because the
disassembler did not know how many arguments to assign to the
unresolved methods. Note: SSDTs can be dynamically loaded at
runtime and may or may not be available via the host OS.
In addition, the -fe option can be used to specify a file containing
control method external declarations with the associated method
argument counts. Each line of the file must be of the form:
    External (<method pathname>, MethodObj, <argument count>)
Invocation:
    iasl -fe refs.txt -d dsdt.aml
iasl I used ver 2017-01-25
MaciASL RM-1.31 (252.3) ACPI 6.1
Then I tried recompile got error:
11867, 6126, syntax error, unexpected '}'
24040, 6126, syntax error, unexpected $end and premature End-Of-File
How can I make it correct, please show me
Thanks all mate!
DSDT Original.zip
there u have it both error free
DSDT Original.zip
(85.18 KiB) Not downloaded yet
Thanks you so much! Error has gone :) . Btw, sorry if I wrong thread, can I have quest? My laptop isn't support wifi native hackintosh, so I replace original wifi with new one ar9285, I inject device using patch #wifi_AR9285-RP02-PXSX.txt and compile but it not work, how to make it correct, bro?
thanks your help, sir! :P
