So after successful installation i found problems with kext for my wifi and trackpad and even the intel hd 3000 which only show 3mb
My laptop specifications are:
CPU: Intel Core i7-2670QM
GPU:Intel HD 3000/ NVIDIA GeForce GT 610M 1 Go DDR3 VRAM
WIFI: Atheros AR9485
Thank you in advance :!::!:
check if work
CLOVER.zip
Still intel HD 3000 3mb
and wifi not working
for video try remove InjectIntel in config.plist
Still nothing
I will try install sierra and see if the problem will solve
k
intel hd 300 is a native, just need one minimal patch
wifi is two kexts in s/l/e and -ath9485 boot arg for AR9485 and -ath9565 for AR9565 (If you don't use any boot args it will do the patching for AR946X by default)
