Hello guys,
Can anyone help me with the issue I have trying to install Mojave?
I manage to install Mojave but when I boot in Mojave partition (the location where I install Mojave) after installation it took almost 5 mins to boot and when the mouse appears on the screen my pc reboot himself. Here is a video showing the issue I face ( https://www.dropbox.com/s/megfxd5kz1him ... M.mov?dl=0 )
I use the Lga775 folder found here in this topic for my Efi partition to boot.
Atm I’m on Sierra and it works fine.
Here is my config:
Gigabyte EP43T-usb 3.0, ich 10 chipset
Intel Quad Core Q9650 3 ghz
Nvidia gtx 1050 2gb
Can anyonw help me with some info on what sertings to use in Clover or which kexts to use? Thank you so much!
Hi MaLd0n,
I mounted the EFI partition and placed DSDT.aml in EFI\CLOVER\ACPI\PATCHED\ and copied all the kext patches in EFI\CLOVER\KEXTS\OTHRS but still sound and LAN is not working.
extract one SEND_ME with new files
RunMe.app
[ref]prashant[/ref], AUDIO ALC 888, check here
Lan, use DPCI Manager/ PCI List tab and check model
Hi MaLd0n,
I followed your video and renamed the device from HDAS to HDEF. I also tried all the layout id's but still so sound.
Please suggest, Did i missed any step.
Added in 4 minutes 27 seconds:
please find my send me files attached. I tried all the ids 1,2,3,5,7,11,27,28,29
Send me Prashants-iMac.zip
[ref]prashant[/ref], try now
inject via clover
Hi MaLd0n,
I replaced dsdt provided by you and tried all the ids 1,2,3,5,7,11,27,28,29 using clover configurator but no luck.
do i need to use rootless=1 in clover?
please help me...
[ref]prashant[/ref], no
use applehdapatcher
[ref]flock[/ref], :guitar
Hi MaLd0n,
I used audio_CloverALC script as i found it relatively easy than patcher and now my sound is working and as per your instructions LAN is also working.
Thanks for your help.
[ref]prashant[/ref], :cap:guitar
Hi MaLd0n.
I am trying to install Mojave on Asus P5Q3 mob. And in disk utility getting this error while formatting HDD "Unable to write to the last block of the device"
no chance
use sierra or high sierra
Hi again @MaLd0n, do you have any idea why I cannot erase my Ssd drive during installation? I have mojave on a Hdd and I put the AppleAhci.kext in s/l/e and i was able to erase the ssd. I try to put the appleahci kext on the usb as well with no success to erase the Ssd during installation. My mobo is Sata2 and ssd is Sata3. I post my config on the above post.
Also mojave is not shutting down well all the time, it takes more then 2 mins when nothing it happens but the screen is black. Do I need a Dsdt patch for my configuration? Thank you!
[ref]flock[/ref], use high sierra and avoid many problems
