Here you are.
update ur clover bootloader for last version and send me new dump, u use very old version
UPDATE FIRST POST
-Clover folder
-Patches
-Mojave
-Cosmetics
Hello
I burn this image to usb using Etcher, install Clover and copy your Clover folder to EFI. But I can't get into install screen, it be panic.
My specs: G41-Combo rev 1.3, E7500, Quadro 600
Hello
the images have all u need, don't need add nothing, clover folder from topic u need patches
NullCPUPowerManagement.kext.zip
Thanks :> I have added the kext what you attach to kexts/other but no success :< still panic same as image I attach above
I use iMac10,1 at SMBIOS, no edit anymore
try other smbios for install iMac14,2 e.g
the NullCPUPowerManagement.kext Kill AppleIntelCPUPM, if don't solve for u, i have no idea
After my problem with Sierra, I tried to install El Capitan, but it doesn't start the install, the screen stuck in "AppleUSBHostPort::interruptOccurred: overcurrent detected"
check log install
Use ever boot key, the system need drivers inside USB Stick
Hello please check my file and thank you
DELL OPTIPLEX 760
macOS high sierra 10.13.6 "iMac10.1"
cpu: core2duo E8400 3ghz
ram: 6gb ddr2
gpu: GT210 1gb
in ur case, old hardware, u can use clover ACPI patches
Hello, can I ask you for DSDT patch ? many thanks
use VID to IGPU patch
5649 445f
49475055
