Does not work entirely, it turns down the screen but the machine doesn´t goes to sleep or even shut down, it remains On, so I hit a key and the image returns, after that I hit the sleep option and it worked, the machine went to sleep, didn´t respond to a hit on the windows keyboard (Mac keyboard does not turn on the machine) so I pressed the ON/OFF button on the PC and the thing woke up (it took more time to do it, about 20 seconds)
:mrgreen::mrgreen:
we check it later, we need out for some hours
Need your help again , this time for my desktop running el capitan.
Specs are :
Gigabyte EP45-UD3R
Intel Q6600
Nvidia 610gt
8gb ram
Thanks in advance for one more time.
Seems ok , except no audio.
What about config.plist and kexts?
Sending new dump file.
CLOVER.zip
REMOVE NullCPUPowerManagement
SEND ME NEW DUMP
RunMe.app
Here you are.
update ur clover bootloader for last version and send me new dump, u use very old version
UPDATE FIRST POST
-Clover folder
-Patches
-Mojave
-Cosmetics
Hello
I burn this image to usb using Etcher, install Clover and copy your Clover folder to EFI. But I can't get into install screen, it be panic.
My specs: G41-Combo rev 1.3, E7500, Quadro 600
Hello
the images have all u need, don't need add nothing, clover folder from topic u need patches
NullCPUPowerManagement.kext.zip
Thanks :> I have added the kext what you attach to kexts/other but no success :< still panic same as image I attach above
I use iMac10,1 at SMBIOS, no edit anymore
try other smbios for install iMac14,2 e.g
the NullCPUPowerManagement.kext Kill AppleIntelCPUPM, if don't solve for u, i have no idea
After my problem with Sierra, I tried to install El Capitan, but it doesn't start the install, the screen stuck in "AppleUSBHostPort::interruptOccurred: overcurrent detected"
check log install
Use ever boot key, the system need drivers inside USB Stick
Hello please check my file and thank you
DELL OPTIPLEX 760
macOS high sierra 10.13.6 "iMac10.1"
cpu: core2duo E8400 3ghz
ram: 6gb ddr2
gpu: GT210 1gb
in ur case, old hardware, u can use clover ACPI patches
Hello, can I ask you for DSDT patch ? many thanks
use VID to IGPU patch
5649 445f
49475055
