[ref]falkortv[/ref], what mobo? u have many in ur sig
Asus P5KPL-AM EPU
MSI GV62-7RD 10.13.6 and W10(i5-7600HQ, 8GB DDR4, 240GB SSD + 1000GB HDD, Intel HD620)
Asus P7P55D-E 10.11 and W10(i5-760, 6GB DDR3, 320GB For Hackintosh, MSI GTX 960 Gaming 2G)
Fujitsu D2841-A11 GS3 10.13.6 - Mounting Hackintosh Custom Build (C2D E8500 3.16Ghz, 4GB DDR2, 250GB HDD)
[ref]falkortv[/ref], extract new send_me
RunMe.app
It was difficult, but I managed to copy it
https://www.mediafire.com/file/49yd0p7h2dkrofr/Send+me+iMac-FalkorTV.zip (But USB 2.0 is disabled to working keyboard, i don't have keyboard for PS/2 to turn on USB 2.0 Function and run RunMe.app)
[ref]falkortv[/ref], ICH7 have a native USB
On my P5KPL only USB 1.0 working, on USB 2.0 don’t working. I can create Video
[ref]falkortv[/ref], without patched DSDT work?
With Disable USB 2.0 Functions - 1/10 Booting Keyboard working
With Enable USB 2.0 -
[ref]falkortv[/ref], try without patched DSDT
I don’t have patched DSDT
[ref]falkortv[/ref], send me files
RunMe.app
[ref]falkortv[/ref], try DSDT.aml.zip
put in clover/acpi/patched and reboot
extract new SEND_ME after reboot
I can’t send, USB 2.0 not working
[ref]falkortv[/ref], u boot from hdd/ssd or USB?
try with usbinjectall
USBInjectAll.kext.zip
Boot From Clover USB. I change MainBoard to Fujitsu D2841-a11 GS 3 and USB Working, I do not have more strength to play with Asus
This kext is on Clover from Olarila HighSierra Image, and don't work on ASUS.
Fujitsu D2841-A11 GS3 Send_me file: http://www.mediafire.com/file/u5eg7u7o0g54afi/Send+me+Fujitsu.zip
[ref]falkortv[/ref], u need boot from hdd/ssd, and don't use usbinjectall, ur usb is native, usbinjectall only if need
falkortv, u need boot from hdd/ssd, and don't use usbinjectall, ur usb is native, usbinjectall only if need
I Used Fujitsu D2841-A11 GS3 Mainboard and working usb native. Asus it will go to the garbage
Fujitsu D2841-A11 GS3 Send_me file: http://www.mediafire.com/file/u5eg7u7o0g54afi/Send+me+Fujitsu.zip . You can create me DSDT?
[ref]falkortv[/ref], DSDT.aml.zip
Okey, copy DSDT and run runme.app - http://www.mediafire.com/file/u6p452kk9f1ez8v/Send+me+iMac-FalkorTV.zip
Fujitsu D2841-A11 GS3(aka Esprimo P3520) have Audio Realtek ALC663 and LAN Broadcom BCM5784M, i can run Audio and LAN on Hackintosh?(Audio on AppleHDA Patcher is for Laptops - versions v1 and v2)
From DPCIManager is -
Audio Devices: 0x808627D8 Sub 0x17341166 nad 0x10DE0BEB sub 0x145834FC
LAN - Vendor 14E4 Device 1698 Sub Ven 1734 Sub Dev 1165
On Fujitsu mainboard only working 2 first USB, USB 3-4 and 5-6 don't working on MacOS(On bios and Windows working)
[ref]falkortv[/ref], use smbios iMac10,1 and -no_compat_check bootargs
falkortv, use smbios iMac10,1 and -no_compat_check bootargs
I change and add bootargs https://www.mediafire.com/file/pbh1ucr0z4qbfke/Send+me+iMac-FalkorTV.zip , but only the first 2 USB works.
EDIT: Working 2 on back, and 2 on mainboard port
[ref]falkortv[/ref], try with clover usb fix, config.plist/acpi tab
I cant even Boot USB thru Olarila Mojave 10.14.1, tried CLOVER.LGA775 instead default USB's EFI Clover and it worked.
But in Installation after selecting language a restart msg appeares.
this version of macos 10.14.1 could not be installed on this computer. Restart.
I tried manually patching insanlymacs https://www.insanelymac.com/forum/files/file/944-mojave-mbr-hfs-firmware-check-patch/ but does not works, shows same msg above.
ASUS P5TMGLX (legacy BIOS, NON efi)
C2D E8500
GeForce GT 710 2GB
[ref]FZSX[/ref], the best for ur hardware is avoid mojave
