Mojave is working well on Hdd and I want to put it on my SSD to be faster. With shutdown I can get use to it :D
So the install on my ssd is the only issue.
[ref]flock[/ref], the problem is support, mojave kill many hardware support, smbios, etc
Do I have any chance that in the future this issue to be fixed? It is strange that before I put the AppleAhci.kext on mojave, erasing the Ssd was not working from mojave as well. After i put that kext i was able to erase the ssd. So in my opinion that kext is good, the only issue is that i think during instalation it use the s/l/e from Osx Base System.dmg and i cannot place that kext in the .dmg image (or can i?). It had no effect to place it Kext folder from Efi partition.
ye, the problem is...apple remove support, kexts, etc in mojave, u need use some from high sierra
Can i edit the s/l/e folder in .dmg image file?
If I can do that i think that kext i use In Mojave atm to format my ssd will work to erase my ssd during the instalation as well.
ye
[ref]gish94[/ref], DSDT.aml.zip
Hi MaLd0n,
I installed Mojave on my machine using your guide and installed multibest post installation. Problem is that I can not boot Mojave from installed HDD but able to boot using my el Capitan usb boot drive.
While booting from HDD i get only blinking cursor only.
Please help me.
I have attached the files.
Send me Prashants-iMac.zip
[ref]prashant[/ref], u can use same files, but with ur hardware the best is stay in high sierra
DSDT and kexts u can use in all systems
Hi MaLd0n,
Thanks for your advice. Definitely i will go for high Sierra. I think multibest is not installed properly on my machine.please guide me on how to uninstall multibest.
[ref]prashant[/ref], never use it, just install clover bootloader and replace full clover folder, btw, for bios, legacy way, use clover version 4522
Added in 3 minutes 48 seconds:
[ref]stillsaad7[/ref], ur processor don't have sse4.2
check here
https://Olarila.com/forum/viewtopic.php?f=62&t=6639
[ref]MaLd0n[/ref],the above guide requires a mac, I dont have a mac however i have a sierra and mojave virtual machine can you give me instructions on how to make a bootable high sierra usb from vm?
Added in 17 minutes 28 seconds:
[ref]MaLd0n[/ref], Will your High Sierra Olarila image and guide would work on my computer?
[ref]stillsaad7[/ref], u need check if ur GPU work in High Sierra, i think no
[ref]stillsaad7[/ref], :cap:guitar
