3 hours ago, Tahsin Faiyaz Sayor said:
Then, how can I make the EFI file on  Windows?
use our premade folder
https://www.olarila.com/topic/5676-folders-for-all-chipsets-clover-and-opencore/
Olá MaLd0n,
Actualizei o opencore para a ultima versão e as kexts, e não consigo dar boot. Experimentei a retirar o ficheiro dsdt que criaste para mim e já arranca.
Será que terá de ser feito outro ajustado ao novo opencore?
Deixo mensagem da tela.
IMG_3798.jpg.zip
Sim
27 minutes ago, MaLd0n said:
Sim
Ok, envio ficheiro criado com o run me de como está actualmente. download
Será necessário mexer em outras configurações no config.plist para ficar preparado para o Monterey?
Outra questão, quando faço sleep, aparentemente tudo funciona bem, mas ao fim de umas horas o pc reinicia sozinho. Se nunca fizer sleep, funciona sempre bem durante o tempo que for necessário.
Obrigado desde já.
Hi @MaLd0n ...I am having random Reboots just after APIC i.e before loading VoodooTSCSync....It reboots. This happens 3 to 4 times and then it boots normally. Then again when I restart it happens 3 to 4 times and then boots normally. I have tried many steps but nothing works. My powermanagement works properly after booting.
I have removed the kexts so that the size is small to upload here.
Please help me.... If I don't use Voodootscsync it never makes into the mac.
I really don't know what to do now..Please let me know if you need any other files..
Motherboard  : Huananzhi X79 Deluxe
CPU                 :  E5 1650 V2
RAM                 :  32 GB
Graphics Card : GT 710 / GTX 1060 Disabled using SSDT
Send me Mac-Pro.zip
Edited by robcodemax
On 11/28/2021 at 6:52 AM, MaLd0n said:
Thankyou verymuch for the reply.
Because of you My inbuild Audio ALC 892 is working...Thanks a ton.....I had been trying to get the audio working for the past 1 month...You solved it in one reply...
Regarding the random reboot while starting
I tried CpuTscSync but it gave a kernel panic.
Screenshot
https://drive.google.com/file/d/1fYLDcc_LKEt_VrC_AF2njdpboXANQCPw/view
I used the DSDT
Archive.zip
try with unc fix
On 11/29/2021 at 8:35 PM, MaLd0n said:
try with unc fix
I removed the UNC0 entry from DSDT and also did a USB Mapping again and now the problem is solved
Thank you very much for your help... You are good at what you do
The most important thing was sound and you got it to work..
For those facing Kernel Panic using CPUTSCSync 1.0.5. Please use CPUTSCSync 1.0.3, I used 1.0.3 and my kernel panic is gone. Don't use 1.0.5
Thanks Once Again
Motherboard: Huananzhi x79 Deluxe
Processor: E5 1650 V2
DDR3 RAM: 32 GB
Graphics Card: GT 710 2 GB
try with unc fix
I just manually removed all the unused cores from DSDT like SCK1 , SCK2 and SCK3 using using Rehabman's MacIasl and then put it in ACPI folder and now everything works without any problem. No more kernel panic. Thank you very much.
Those who are using 6 Cores 12 Threads CPU and Huananzhi X79 or Chinese X79 Motherboard can use DSDT_ROBERT.aml
Others can use DSDT_OLARILA.aml which will support more cpu cores. You can edit this DSDT and remove the unused cores like I have shown below, just delete those entries
188009-screen-shot-2021-12-13-at-11-45-0
188010-screen-shot-2021-12-13-at-11-46-0
188011-screen-shot-2021-12-13-at-11-48-2
DSDT_ROBERT.aml.zip
DSDT_OLARILA.aml.zip
Nice.
Enjoy!
Hi @MaLd0n....I have one more question
I have two graphics card in Slot 1 I have GTX 1060 which I have disabled using SSDT and in slot-2 I have GT 710.
I want to know is there anyway to get the verbose showing in GT 710 currently verbose is shown in GTX 1060.
1060 is disabled? check with ioreg
Yes It is disabled. I checked Ioreg as well.
One more issue is that the machine is not able to wake from sleep. The screen Keyboard and Mouse never comes on. Then I have to forcibly shutdown and then restart
188154-screen-shot-2021-12-14-at-11-28-3
Is it possible to get sleep working in x79 motherboard.. Mine goes to sleep but never comes back.. No screen no keyboard no mouse
sleep don't work good on x79 platforms
