3 minutes ago, jakes said:
I have ACER Aspire VN7-591G with intel hd 4600 Graphics and cant get full acceleration, it says 7 MB.
https://www.olarila.com/topic/6420-guide-mobile-intel-hd-graphics/
14 minutes ago, jakes said:
Do I have to put this plist in Clover and reboot, or I have to do something else, sorry I am new and want to have your Hackintosh installed.
apply a video patch into ur config.plist
hi everybody, I'm tryng to install high sierra on a hp dv5 intel, but i receive some errors even if I select config 2 as suggestion for notebook users. can you please help me? is the first time that i install a mac and even the first time that i use a mac in my life!?
here the image of the error:
thank you for your help!
inject device EC with SSDT for install
@MaLd0n i'm trying to install macOS catalina on my old pc, specs CPU - Intel Core i5 2400 , Mother Board - GigabyteGA-H61M-S2P-B3 (rev. 1.0) Graphic - Intel® HD Graphics 2000 Ram - 8GB DDR3 Storage - WD 240GB SSD, Sandisk 120GB SSD, Seagate 1TB HDD
i keep getting this version of macOS cannot be installed on this computer and i also tried high sierra, with high sierra it restarts half way through the verbose, what should i do ?
@MaLd0n i also got this same error on new 10th gen laptop, Asus x509ja.
Core i3 1005G1
Intel uhd graphics
Core i3 1005G1
Intel uhd graphics
changed smbios to 14,1 fixed the issue im having with catalina on i5 2400
Hello Maldon
Clover I use AptioMemoryFix.efi I would like to use OcQuirks.efi for my motherboard how should I set it
https://github.com/ReddestDream/OcQuirks
22 minutes ago, iFabio said:
removed AptioMemoryFix.efi and installed OcQuirks.efi all working
good
just enjoy
On 3/9/2018 at 7:07 AM, MaLd0n said:
 -Donations with PayPal
https://tinyurl.com/r2bvzm7
-Donations with Bitcoin
33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3
-Donations with PicPay
@danielnmaldonado
1--Download Olarila Image--
https://www.olarila.com/topic/6278-new-olarila-images/
2--Tutorial Install MacOS with Olarila Image, Step by Step, Install and Post Install--
https://www.olarila.com/topic/5794-guide-install-macos-with-olarila-image-step-by-step-install-and-post-install-windows-or-mac/
3--EFI Folders for Chipsets--
https://www.olarila.com/topic/5676-folders-for-all-chipsets-clover-and-opencore/
4--DSDT Patch Request--
https://www.olarila.com/forum/17-dsdt-patch-requests/
If you are a donor use a personal room and support!
https://www.olarila.com/forum/90-?-donators-room/
-Credits and thanks to the old and new people in the community who developed patches, kexts and bootloaders!
Slice, Kabyl, usr-sse2, jadran, Blackosx, dmazar, STLVNUB, pcj, apianti, JrCs, pene, FrodoKenny, skoczy, ycr.ru, Oscar09, xsmile, SoThOr, RehabMan, Download-Fritz, Zenit432, cecekpawon, Intel, Apple, Oracle, Chameleon Team, crazybirdy, Mieze, Mirone, Oldnapalm, netkas, Elconiglio, artut-pt, ErmaC, Pavo, Toleda, Master Chief and family, bcc9, The King, PMheart, Sherlocks, Micky1979, vit9696, vandroiy2013, Voodoo Team, Pike R. Alpha, lvs1974, Austere.J, CVad and many, many, many others!
hey Mald0n
I have an audio problem not detected in Run me.app and hackintoshtool. i have followed the installation steps but it doesn't work. I also have a problem with the brightness hotkey remapping. When I patch text there is a problem that it can't be saved
mac os catalina 10.15.3
dell inspiron 3421 intel i3 1,8ghz ram 4gb vga intelhd4000 and nvidia 625m wificard AR9565
intelHD4000 and wificard work
does not work
sleep
brightness hotkey
audio is not detected
PCI not detected
help me Mald0n
I need a patched DSDT
Send Me.zip
4 hours ago, IGosa Bagus Yuniarta said:
My audio not working, i check use manufacture page ALC3221 and brigthness hotkey remapping after I copy patch can't save
On 9/22/2020 at 9:41 AM, MaLd0n said:
thanks mald0n
audio works fine and hotkeys work fine
hotkey brightness works but when I press Fn + F5 to increase the direct lighting it increases to the maximum and I press Fn + F4 to decrease the direct lighting to decrease to a minimum, even though I press it once
I've tried to copy and paste the patch but still unchanged
Olá MaLd0n,
Não sei se têm acontecido com mais pessoas, mas estava a fazer um benchmark com o geekbench em Metal à minha Vega 56, e consigo 59423 com o DSDT que me criaste.
Experimentei remover o DSDT e fazer reboot e dá 81275, o que poderá ser?
Não sei se é normal ou não, mas noto que a Vega sempre que abro um vídeo fica ao máximo Mhz da memória RAM, e só passa se reiniciar o hack.
uran0s-macpro.zip
Edited by uran0s
5 hours ago, uran0s said:
Olá MaLd0n,
quando se ativa o gerenciamento de energia, etc que os problemas começar a aparecer.
a galera usa uma ssdt pra correção desse problema
Ok. Então devo usar à mesma o DSDT? E que SSDT devo usar para correcção do problema?
