Hi [ref]MaLd0n[ref]
I read the WhateverGreen FAQ and followed the steps, but it didn't work on my machine.
I used the EFI folder you provide me and I updated the WhateverGreen.kext and Lilu.kext. After that Iput away the DSDT.aml from the patched folder because I couldn't make the system work correctly.
After I removed the DSDT.aml from the patched folder, I configured my config.plist with some modifications and now it seems to work as expected, except for one little but weird thing.
On Chrome, there's a weird glitch with the icons when I mouse over them. I attach some screenshots above.
Although the Graphics section on About this Mac is showing the correct information:
Do you know what's happening? How can I fix it?
Also, do I need an additional DSDT? Could you help me with that?
I attach the Send_me file so you can see my EFI.
http://s000.tinyupload.com/index.php?file_id=03566923852576978250
Thank you for your time and help!!
:guitar :guitar
use iMac18,1 smbios to avoid glitches
I've tested with iMac19,2 and iMac18,1. Same result.
With the last DSDT.aml the problem gets worst:
What does the DSDT do?
Here is the Send_me:
http://s000.tinyupload.com/index.php?file_id=55017602999398463531
Thanks!!
25 minutes ago, pepe21 said:
Thanks!!
config.plist.zip
[ref]MaLd0n[ref] same result but without verbose boot log.
Also I need to unplug and plug my monitors so the system can recognise them and provide video to them, otherwise there is no signal.
What is the DSDT.aml doing? What fixes?
Thanks!!!
Quote
-FIX ERRORS AND WARNINGS
-FIX ACPI ERRORS
-REMOVE UNUSED SCOPES / DEVICES
-HIGH PRECISION EVENT TIMER
-SATA SERIE ID
-DMAC
-REMOVE LINES, PROBLEMATIC and UNUSED
-FIX K.P in REBOOT
-NVRAM
-REAL TIME CLOCK
-SLPB
-DARWIN / WINDOWS
-XHCI
-PLUGIN TYPE
-HDEF
-ARTC
-IPIC
-TIMR
-SBUS
-BUS1
-MCHC
-ALS0
-SHUTDOWN
-UAR1
-LAN
-FWHD
-USBX
-PMCR
-PPMC
-XSPI
-GMM
-kUSBCompanionIndex
-io-device-location
-IMEI
-EC
-PNLF
-ARPT
-GFX0
-NVME
-ACPI-WAKE-GPE
-DTGP
-ACQUIRE MUT0 0XFFFF
-MUTEX MUT0 0x00
-EXTERNAL REFERENCES
-UNKNOWNOBJ
-HDMI / HDAU
-FULL RENAMED DEVICES
Nothing about video
5 hours ago, MaLd0n said:
Nothing about video
IMEI, GFX0, HDMI / HDAU
Maybe this is the problem?
I have this DSDT patches on config.plist:
Comment - Find - Replace
GFX0 to IGPU - 47465830 - 49475055
HECI to IMEI - 48454349 - 494D4549
HDAS to HDEF - 48444153 - 48444546
no
check csm option in bios/uefi setup
CSM support is disabled on my motherboard BIOS config.
If I active it, the result is the same.
no idea what happens :smoke:
I have a trouble with pen drive installation bootloader. I think is because my SSD HD is M.2 but plugged in PCI-e x16, so after install OSX by pen drive the Clover Boot don't recognizes SSD Drive to continue installation by it.
I have the same trouble with High Sierra new Olarila images, but with an old High Sierra 10.13.6 img (torrent download) i had successful. After pen drive installation, the bootloader recognizes SSD normaly and continue install perfectly. Unfortunately after install i can't success on install clover BL in SSD HD. Well, i tried with inumerous form and noone run boot, whatever that i do the MOBO always tell-me that have no boot devices then the pendrive.
I tried install windows 10 home to and a i have a same problem, after pen drive installation no boot from SSD HD, I'm pretty convinced that the problem is because i using an adapter M.2 to PCI-e.
Well, by the logic if the cloover bootloader configured in HS1.13.6 img working, so maybe i can make a specific pen drive boot for Mojave with the right configuration or kext to recognizes my HD SSD, or maybe some modification in a cloover bootloader of Mojave instalation. Is it possible?
MOBO: Gigabyte GA-B85M-D3H
Processor: Core I5 4690 3.5v
Hd Ssd Adata M.2 512gb Xpg Gammix S11 Pro Pci-e Gen3x4
This is the adapter image:
2 hours ago, Tiago Gabriel Musardo Firmino said:
I have a trouble
is native
8 hours ago, Tiago Gabriel Musardo Firmino said:
Sorry, what is native?
ssd, nvme
22 hours ago, MaLd0n said:
ssd, nvme
The problem is the MOBO doen't support M.2. I wrote to gigabyte and they r tell-me this, so i solved my problem instaling a SATA HD and wala, clear instal, runing and booting without the pen.
Now i can't configure the ethernet, this is the unique thing that doesn' work yeat, sound and video r ok. can help-me to solve the ethernet?
Ahh yeah, i tried to install windows and many linux distro to test a bootloader and no-one works. lol
Adaptors are never good the original support
Edited by Tiago Gabriel Musardo Firmino
check what lan card u have
use DpciManager
use Mieze kext
I have ACER Aspire VN7-591G with intel hd 4600 Graphics and cant get full acceleration, it says 7 MB.
I have tried so much but nothing works
So help would be much welcomed
BTW I appreciate your work here, it is great
Thanks a lot
