1 hour ago, uran0s said:
Já testei as várias smbios, sendo que a smbios do iMacPro 1,1 é a que melhores resultados me oferece.
use o iMacPro1,1. A solução é muito boa
On 3/29/2020 at 5:14 PM, MaLd0n said:
Check last Olarila folder
checking the config.plist I see Fix bug RTC I have to use it
for patch "com.apple.driver.AppleRTC"
Edited by iFabio
i dont need it with my dsdt
On 3/28/2020 at 4:38 PM, MaLd0n said:
no idea
after 10.15.4?
still can't sign out of iCloud, even offline.
removed this computer from my iCloud and signed back in when it asked for my password even though it didn't offer a sign in button, still having the same issue.
looking into clearing iCloud from my hack, but here's a run me. maybe you will see the problem in there?
can't send or receive iMessages, App Store goes to not responding.
Booted from a clover usb and App Store works fine, updated to the latest OpenCore and it wouldn't boot.
definitely a OpenCore issue.
https://ibb.co/bW3WZ41
Screen-Shot-2020-04-02-at-11-14-47-AM.pn
https://ibb.co/z6Sq3Kr
Screen-Shot-2020-04-02-at-11-14-25-AM.pn
Send me iTerrorByte.zip
Edited by fallen00sniper
remove files into library/preferences/systemconfiguration
run it
https://olarila.com/files/Utils/iMessage Fixer.app.zip
reboot
System: Gigabyte H97-HD3, i5 4690, Radeon Rx 580, Mac compatible Wifi/BT PCI.
Been running Hackintosh for a long time. Needed to buy a new SSD as the old one is aging so did an Oralila install using the guide.
Happy to say everything went well using the default setting including the standard Clover.plist from here.
As everything is at default, I think it is using AppleALC/Lilu with the device hardware detect set at 1 (Realtek ALC887 sound chip) motherboard front headphone jack works. Have not tried the back sound ports becasue I have been using the Audioengine D1 USB DAC for the last 6-7 years since my first Hackintosh! This DAC has a headphone jack as well which obviously works and sounds better.
However, with this setup, I cannot get the PCI Toslink/SPDIF (This is on a riser card) to work although a "digital out" is detected. This is not too critical but the main issue I have is the more frequent "pop" sounds from the USB sound. This is just annoying as it is unpredictable especially when multitasking. In my previous Mojave setup (using Oralila's method), the SPDIF works only with VoodooHDA installed and there was hardly any pop sounds. I think it is the same issue here.
Has anyone solved these 2 problems - working SPDIF and pop sounds using the AppleALC? I have tried all the device ID recommended for the ALC887 but only 1 and 7 reflect my hardware.
Somehow VoodooHDA has some special sauce in it. Should I use this instead of AppleALC/Lilu? Pro and cons?
BTW, if I remember correctly in my previosu Mojave setup, I left the AppleALC/Lilu in place and simply installed VoodooHDA and straight away the SPDIF/Optical was detected. No need to uninstall AppleALC/Lilu?
Thanks.
Edited by mengshi
Greetings guys.
I have recently updated my EFI folder to the latest uploaded version and have noticed some new changes.
My system boots well but on the screen before clover I get this.
OSC: No schema for ProtectSecureBoot at 8 Index!
OSC: No schema for ProtectUefiServices at 9 Index!
have I to do something ? Or ignore it
Thank you
2 hours ago, Josele said:
Greetings guys
u can ignore it
Hi MaLd0n!!
I just installed OS X Catalina 10.15.4.
My system is:
Mobo: Gigabyte Z370 HD3P
Processor: Intel Core i7 8700
Graphics Card: nVidia Geforce GTX 970
Since my card is not supported, I'm getting 7mb of graphics memory. I have 2 monitors connected to GTX 970, 1st slot by DisplayPort (the one is working and using right now) and 2nd slot by HDMI (not working at all).
I know GTX 970 is not supported on Catalina, but I have Intel HD Graphics on my processor, so I was wondering if I can disable nVidia graphic processor and activate Intel processor.
Is this something related with DSDT? I did some research but conclusions weren't too clear for me. Could you help me pls?
My goal is to build a system to use Xcode and some other software to develop Web and Native apps. Could I work with this machine?
I attach my Send me file here:
http://s000.tinyupload.com/index.php?file_id=08141942708843091071
Thanks for your help as always!!
:guitar:guitar
enable intelhd with hackintool
58 minutes ago, MaLd0n said:
hackintool
Hi MaLd0n,
I just added the DSDT and my system is not booting, it freezes on the booting secuence, on the line:
AppleKeyStore: operation failed (pid: 282 sel: 7 ret: e00002c2 ´-563870206´, -1, 100000)
Also I was searching for the option to enable intelhd on hackintool but I'm not able to find it... can you help me pls?
Thanks!!
Szia Mald0n!
újra szükségem van a segítségedre. az előző 4k videólejátszással kapcsolatos probléma nem szűnt meg, ezért a gpu-t kicseréltem az amd radeon pro wx7100-ra, de a videó lejátszása még mindig elmarad. ha megnézné, köszönöm.
https://www108.zippyshare.com/v/cvCOpMPM/file.html
and if you could persuade me to give an image on both hdmi and dvi ports, that would be great.
Edited by bora01
I forgot something
config looks good, now u need a some personal things
2 hours ago, bora01 said:
video patch for example
Hi MaLd0n:
I builded this code with hackintool trying to enable intelhd, but I think I did wrong:
<key>Properties</key>
		<dict>
			<dict>
				<data>BwCbPg==</data>
				<key>AAPL,slot-name</key>
				<string>Internal@0,2,0</string>
				<key>device-id</key>
				<data>kj4AAA==</data>
				<key>device_type</key>
				<string>Display controller</string>
				<key>framebuffer-con0-enable</key>
				<data>AQAAAA==</data>
				<key>framebuffer-con0-pipe</key>
				<data>EgAAAA==</data>
				<key>framebuffer-con1-pipe</key>
				<key>framebuffer-con2-pipe</key>
				<key>hda-gfx</key>
				<string>onboard-1</string>
				<key>model</key>
				<string>Intel UHD Graphics 630 (Desktop)</string>
			</dict>
		</dict>
If I use the DSDT.aml you provide me before there are multiple glitches and when I don't put it on the ACPI, I open any app which needs hardware acceleration (Chrome or Spotify for example) or even a website like mediafire and my system reboots.
Also the Graphics section on About this Mac is empty, I attached a screenshot on the Send_me file.
Can you help me please?
http://s000.tinyupload.com/index.php?file_id=41545792607994124140
Thanks!!
