Hello Maldon
update 10.15.4 which KextsToPatch should I add for hardware in the signature
4 minutes ago, fallen00sniper said:
@MaLd0n App Store beach balls and messages doesn't seem to work correctly anymore, any ideas?
no idea
after 10.15.4?
3 minutes ago, MaLd0n said:
no idea
after 10.15.4?
Yea, but it was doing it before.
i added images to iCloud on my computer and they never made it to my phone.
just an iCloud issue I think, but I can’t sign out ?
messages seem to update on the hack when it wants to.
Edited by fallen00sniper
14 hours ago, MaLd0n said:
Clover r_5107
I was referring to which KextsToPatch should I add for hardware in the signature
I use these patches but I don't know if they are needed for my hardware
where I find explanation of these patches
<dict>
				<key>Comment</key>
				<string>Prevent AGDP from loading</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				ugUAAAA=
				</data>
				<key>InfoPlistPatch</key>
				<false/>
				<key>MatchOS</key>
				<string>10.13.x,10.14.x,10.15.x</string>
				<key>Name</key>
				<string>com.apple.driver.AppleGraphicsDevicePolicy</string>
				<key>Replace</key>
				<data>
				ugAAAAA=
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>MikeyDriver Patch Assertions</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				U291bmQgYXNzZXJ0aW9uIA==
				</data>
				<false/>
				<key>MatchOS</key>
				<string>10.11.x,10.12.x,10.13.x,10.14.x,10.15.x</string>
				<key>Name</key>
				<string>com.apple.driver.AppleMikeyDriver</string>
				<key>Replace</key>
				<data>
				AAAAAAAAAAAAAAAAAAAAAA==
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>AppleHDA Patch Assertions</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				</data>
				<false/>
				<key>MatchOS</key>
				<key>Name</key>
				<string>com.apple.driver.AppleHDA</string>
				<key>Replace</key>
				<data>
				</data>
			</dict>
7 hours ago, iFabio said:
Clover r_5107
Check last Olarila folder
On 3/27/2020 at 2:04 PM, MaLd0n said:
está legal
Obrigado.
Já alguma vez te aconteceu a placa gráfica prender a memória na frequência máxima?
Às vezes fica presa nos 800MHZ, e por mais que feche todas as APPS, etc, só volta ao normal reiniciando o mac.
Agora que fiz uma série de mudanças ao mesmo tempo, não sei do que será, ou seja, actualização de 10.15.3 para 10.15.4, de Clover para OC, de só GPU, para GPU + IGPU.
Antes nunca me tinha apercebido deste problema.
Já voltei a desligar a IGPU para teste, mas acontece à mesma.
Noto em especial, quando uso Youtube no Safari, assim que muda automaticamente de vídeo, fica imediatamente a 800MHZ e não sai, só reiniciando.
Edited by uran0s
35 minutes ago, uran0s said:
Obrigado.
não faço idéia
done
Question: for my hardware I have to use SystemProfilerMemoryFixup.kext
41 minutes ago, fallen00sniper said:
Any ideas for what I can do?
no idea, need check
19 hours ago, MaLd0n said:
não faço idéia
Julgo ter descoberto.
Estava a usar a flag shikigva=128, o que me dava acesso a ter descodificação por HW para H264 e H265 no VideoProc, mas fico com esse problema, sempre que visualizo um vídeo, a memória prende no máximo, e só volta a baixar aos 500MHZ quando volto a visualizar outro vídeo.
É esta situação normal? Também acontece consigo?
Agora experimentei usar shikigva=16, mas perdi o H265, fica só H264 através do IGPU, mas o problema da memória prender ao máximo de MHZ já não acontece.
Qual o shikigva correcto?
1- vc pode usar com a intelhd ativada(intel quick sync)
2- pode usar iMacPro1,1 smbios ou MacPro7,1 smbios, os dois tem hw nativo
3- vc pode usar o smbios correto com a flag shikigva=128 ou 144 com gpus amd sem a intelhd ativada
Obrigado, vou experimentar ambas as soluções a ver qual funciona melhor para mim.
Só mais uma questão, ao usar uma Smbios diferente como iMacPro1,1 ou MacPro 7,1 necessito de usar kext CPUFriend? Ou o PM irá funcionar correctamente no meu CPU?
funciona bem
Hi @MaLd0n,
Please would you mind helping me get a setup files for Catalina?
For SMBIOS should I go with "Macmini6,2" or "iMac13,1"? I also want to know if the sound will work?
Please, let me know.
Thank you!
CPU: i7-3770K
GPU: Intel HD Graphics 4000
RAM: 2x4GB DDR3 1333
HDD: PNY CS900 120GB SSD
Motherboard/Chipset: Ivy Bridge H61 (ECS H61H2-M12 v1.0)
Ethernet: Qualcomm Atheros AR8152
WiFi: N/A
BT: N/A
Monitor: LG E1942 / 16:9 / 1366 x 768p / connected via VGA cable
iMac13,2 nd generate one ssdt for good PM
https://www.olarila.com/topic/6451-guide-generate-ssdt-for-power-management-with-ssdtprgen/
funciona bem
Já testei as várias smbios, sendo que a smbios do iMacPro 1,1 é a que melhores resultados me oferece.
O único senão, continua a ser o mesmo, sempre que abro um vídeo no youtube/finder e o fecho, a memória prende a 800mhz.
Alguém com VEGA e iMacPro1,1 por aí que me possa dizer se lhe acontece o mesmo?
