Thanks, it appears the link on the sticky was the issue earlier. :)
Will also try the new link you gave.
My First Hackintosh: GA-Z390 Gaming M/Intel Core i5 9400F/32GB G.Skill 3600/MSI RX6600XT
and don't work?
12 hours ago, wastedbrain said:
The one in the sticky does not: https://www.olarila.com/forum/78-donators-room/ <<<---does not work for me.
this link is die now xD
Hi Mald0n!
I am sending you Send me file for my Dell Optiplex 7010.
I problem with system when a play 4k UHD movie and my system is too slow.
Please help me a dsdt, clover setting and what can be done with it.
https://www26.zippyshare.com/v/sLx47uj2/file.html
https://www26.zippyshare.com/v/sfOLrXYg/file.html
Thank you so very much.
20 hours ago, bora01 said:
Hi Mald0n!
u need use Olarila folder for ur chipset, reboot and extract new
Hey Maldon,
Moved iTerrorByte into iFrankies old case, the front USB ports aren't working yet, but other than that can you check my run_me and let me know if I am still good?
Retired iFrankie as a hack for now... it's all gaming machine now, but iTerrorByte has been legit! ?
Do you happen to get on any of the hackintosh discords? miss our chats from slack. ?
https://drive.google.com/file/d/1qrpv40Akh9CeSWN5h8P2xAsQkaUx1gdU/view?usp=sharing
Kind of forgot to remove the bluetooth usb dongle, don't need it anymore with the apple wifi card from iFrankie. ?
Edited by fallen00sniper
max file upload is too small for a run_me
9 hours ago, fallen00sniper said:
Hey Maldon
  • Thanks 1
2 minutes ago, fallen00sniper said:
Have you messed with openCore any lately?
ye
work good too
14 hours ago, MaLd0n said:
ye
work good too
I'd like to try it out, started building a thumb drive for testing.
Also, there are two ports on the back of this hack that are usb 2.0, Mac sees them as 3.0, the 13 port hub I have connected is usb 2.0 and actually getting power from the usb 2.0 port which is strange ?
11 minutes ago, bora01 said:
Hi Mald0n!
