Administrators MaLd0n Posted December 21, 2019 Author Administrators Posted December 21, 2019 [ref]Minipomy[/ref], i have no idea, i don't use it -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
chicoray Posted December 31, 2019 Posted December 31, 2019 chicoray, is about nvidia web driver check if have update Hey Maldon, I updated high sierra security update and nvidia webdriver. It was running fine for the last week but then it made another KP this morning. (the computer's been running all night, maybe that's related..) obviously it wasn't in débug mode, so i just have the log here's the log if you feel having a look Kernel_2019-12-31-120722_iMac-Pro-de-Richard.panic.zip
Administrators MaLd0n Posted December 31, 2019 Author Administrators Posted December 31, 2019 [ref]chicoray[/ref], is about nvdia web driver -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
chicoray Posted December 31, 2019 Posted December 31, 2019 ok, so there is definitely a problem with this video card and high sierra (it was running fine with yosemite)
Administrators MaLd0n Posted December 31, 2019 Author Administrators Posted December 31, 2019 [ref]chicoray[/ref], work good in high sierra too, is a strange problem, u downloaded web driver from nvidia or use script for install? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
biondoita3000 Posted January 3, 2020 Posted January 3, 2020 hi MaLd0n, where i send you the file of "runme.app" ? tnx in advance
Administrators MaLd0n Posted January 3, 2020 Author Administrators Posted January 3, 2020 [ref]biondoita3000[/ref], https://Olarila.com/forum/viewtopic.php?f=19&t=1131 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
biondoita3000 Posted January 3, 2020 Posted January 3, 2020 hi [ref]MaLd0n[/ref], biondoita3000, viewtopic.php?f=19&t=1131 ok that's my file , the system boot ok ( high sierra ) but some miss (ethernet) and the cpu fix to 100 usage and the benchmark is so horrible . tnx in advance for your help !!!!! https://filebin.net/n80kfsu9pfb9k0df/Send_me_Emyxs-Mac-Pro.zip?t=hq0adozc
Administrators MaLd0n Posted January 3, 2020 Author Administrators Posted January 3, 2020 [ref]biondoita3000[/ref], DSDT.aml.zip use correct folder, x99 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
biondoita3000 Posted January 4, 2020 Posted January 4, 2020 biondoita3000, DSDT.aml.zip tnx so much !!!!!!!!! , i use clover x99 folder you mean ? and where i put this file ? in efi clover ? tnx for your patience
Administrators MaLd0n Posted January 4, 2020 Author Administrators Posted January 4, 2020 [ref]biondoita3000[/ref], clover/acpi/patched yes, use Olarila folder x99 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
wladekjajcobladek Posted January 4, 2020 Posted January 4, 2020 Hi I am trying to install catalina on ASUS P8Z68-V PRO with i7 2600k Can't do even a first boot. tried Olarila high sierra too still no success. Normal bios settings bios updated to the newest no video card . I have radeon hd 6590 but i guess this one is not supported so it does not make any sense to use it. I have copied / replaced to EFI of the pendrive the Folder Chipset Series. I am booting with following: halt enabler generate CS and PS states. with and without patch apic . with fixMCFG with without debug dsdt. with and without injectintel . with kernel pm with panic no kext dump with appleintelcpupm and apple rtc. After successfull install i would like to overclock this system. I don't care catalina or high sierra anything that can run on this old setup. Will use mostly for adobe cc apps ps il and premiere . May add a video card later on if i manage to exchange 6950 for something supported. This is a no budget project and overclocked i7 2600k works like a charm on windows ... the problem is i don't like windows so hope i can install osx on it. Previously i had mojave and high sierra on sandy bridge i3 and different mobo gigabyte installed with Olarila images in that case installation was quite easy. I had impression that sierra was much faster than mojave. Which one would be better for i7 2600k? Why this time i can't get it to boot? Please help IMG_0829-kopia.jpg.zip
Administrators MaLd0n Posted January 5, 2020 Author Administrators Posted January 5, 2020 [ref]wladekjajcobladek[/ref], https://Olarila.com/forum/viewtopic.php?f=50&t=8685 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
wladekjajcobladek Posted January 5, 2020 Posted January 5, 2020 An update ... Managed to first boot and install high sierra. I have patched BIOS with UEFIpatch Installed clover on ssd after installation it won't boot but it does if i use bootloader from usb. i have run disable hibernate disable master then the run me. what else needs to be done to make it work properly? should i do this DSDT patching even with patched bios? Please help
Administrators MaLd0n Posted January 5, 2020 Author Administrators Posted January 5, 2020 [ref]wladekjajcobladek[/ref], with old hardware u can try a dosdude tool for one personal usb stick -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
wladekjajcobladek Posted January 5, 2020 Posted January 5, 2020 Thank you, Tried dosdudes before no success. However I have installed now and it boots up in verbose I can see unsupported cpu etc. Once booted up there is no audio and benchmark seems to be low. I have overclocked in bios but looks like not overclocked at all. what is the best way for post install? It appears as Mac mini mid 2011 clover was showing Mac mini 5,1
wladekjajcobladek Posted January 6, 2020 Posted January 6, 2020 Installed Catalina however my ssd seems to bo not bootable I can boot from it choosing it from boot options (F8) but only if i have a pendrive with clover. Had problems installing clover on ssd finally installed after running make my disk readwriting and sudo mount -uw / I can mount EFI on my ssd and make changes to config.plist but on boot i see same settings unchanged.
Administrators MaLd0n Posted January 6, 2020 Author Administrators Posted January 6, 2020 [ref]wladekjajcobladek[/ref], check full procedure here https://Olarila.com/forum/viewtopic.php?f=50&t=8685 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
wladekjajcobladek Posted January 6, 2020 Posted January 6, 2020 Thank you MaLd0n All steps as on guide. with two differences: Replace Clover folder with Olarila Clover folder Download Clover folder for your Chipset Downloaded settings kext did not work i have used some other files for EFI both pendrive and EFI on my ssd. Installing Clover EFI I could not find one of the options selected on the screenshot in the guide HFSPlus-64 For the rest I have proceeded exactly as described in the guide up to the reboot point 8 did not 9- Fine Tune, DSDT as it won't boot from ssd . Added in 18 minutes 23 seconds: my diskutil list Untitled.jpg.zip
chicoray Posted January 8, 2020 Posted January 8, 2020 chicoray, work good in high sierra too, is a strange problem, u downloaded web driver from nvidia or use script for install? Hi Maldon, I downloaded the webdriver from the nvidia website
