iFabio Posted December 7, 2019 Posted December 7, 2019 tip to try open core I7 4770K - Z97-PRO Wifi (ac) - Intel HD4600
Administrators MaLd0n Posted December 7, 2019 Author Administrators Posted December 7, 2019 [ref]dillannonas[/ref], https://Olarila.com/forum/viewtopic.php?f=50&t=8685 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
iFabio Posted December 7, 2019 Posted December 7, 2019 I followed the guide https://Olarila.com/forum/viewtopic.php?f=28&t=8268 I inserted the SSDT table in EFI/Clover/acpi/patched/SSDT Boot.log I am 7: 924 0: 000 Table entry [0]: SSDT-1.aml from EFI CLOVER ACPI with patch: ... not found because it indicates SSDT-1.aml and not SSDT.aml question: also generate SSDT data using the CPUFriend script Thanks I7 4770K - Z97-PRO Wifi (ac) - Intel HD4600
Administrators MaLd0n Posted December 7, 2019 Author Administrators Posted December 7, 2019 [ref]iFabio[/ref], u can use all, just need add entrie in config.plist -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
dillannonas Posted December 8, 2019 Posted December 8, 2019 dillannonas, viewtopic.php?f=50&t=8685 Hello again. follow the tutorial to the letter and boot0ss: error. install clover with mbr boot00s with various configurations and get an error uefi windows. boot00s and boot0af starts windows mbr and partitions in gpt but does not install
dillannonas Posted December 8, 2019 Posted December 8, 2019 I got an error with boot00s that says: Windows failed to start. A recent hardware or software change might be the cause. To fix the problem: 1. Insert your Windows installation disc and restart your computer. 2. Choose your languaje settings, and then clik “next”. 3. Click “Repair your computer.” If you do not have this disc, contact your system administrator or computer manufacturer for assistance. File: \Boot\BCD Status: 0xc000000e Info: the boot configuration data for your PC is missing or contains errors.
iFabio Posted December 8, 2019 Posted December 8, 2019 iFabio, u can use all, just need add entrie in config.plist can you tell me where in config.plist I7 4770K - Z97-PRO Wifi (ac) - Intel HD4600
iFabio Posted December 10, 2019 Posted December 10, 2019 Hello Maldon I can't boot with Catalina's macOS with the DSDT that I use for macOS Mojave you could check it macials using https://github.com/acidanthera/MaciASL/releases gives me an error Thanks no longer booting me even in macOS Mojave I have to delete the DSDT new send me http://www.filedropper.com/sendmefabios-imac DSDT.aml.zip I7 4770K - Z97-PRO Wifi (ac) - Intel HD4600
iFabio Posted December 13, 2019 Posted December 13, 2019 thanks the same solved I7 4770K - Z97-PRO Wifi (ac) - Intel HD4600
htpcomputer Posted December 17, 2019 Posted December 17, 2019 Can you send me code of patches bellow? Thank you! - FIX ERRORS AND WARNINGS -HPET -SATA -DMAC -SLPB -DARWIN -EHCI -XHCI -PLUGIN TYPE -XXXX to HDEF -HDEF -RTC -IRQs -SBUS -MIKEY -BUS1 -MCHC -ALS0 -SHUTDOWN -LAN -USBX -IMEI -EC -PNLF -GFX0 -HDAU -NVME -ARPT -INTELHDGRAPHICS
Minipomy Posted December 20, 2019 Posted December 20, 2019 Goodnight! I own an HP Envy x360 15-u110dx Cpu: i5 5200U Ram: 8gb Igpu: hd5500 Bios: insyde F.41 Jun 21, 2018 Disc: ssd wd green 480gb When I try to run the usb with the Mojave 10.14.6 I throw kernel panic with the config2.plist. frustrated, I tried to make my own Clover[v5070](with the chipset folder for 9 series notebooks), and it didn't work out either. I already tried both with the latest version of High Sierra and Mojave (It should be clarified that 2 years ago I managed to install high sierra with the old build of the clover, I tried to do exactly the same or as I remembered and it did not work, since I had conflict with the versions of the aptiomemfix. also, I used [in High Sierra back then] a DVMTpreAlloc, because my BIOS does not allow changing the DVMT - the option does not even appear) I'm quite new on the subject I would appreciate a help Cheers!
chicoray Posted December 20, 2019 Posted December 20, 2019 Hi Maldon, I'm experiencing random kernel panics with my hackintosh so I'm trying to reinstall High Sierra using your method. My hardware is gigabyte x99 ud4 - i7 5960x - gtx970 Do i need to put a DSDT in the install USB flsh drive ? here's my sendme file http://www.filedropper.com/sendmeimac-pro-de-richard cheers
Administrators MaLd0n Posted December 20, 2019 Author Administrators Posted December 20, 2019 [ref]htpcomputer[/ref], nope [ref]Minipomy[/ref], post one photo [ref]chicoray[/ref], need check what cause it, use -v, debug=0x100 and keepsyms=1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
chicoray Posted December 20, 2019 Posted December 20, 2019 Hey Maldon, Thanks. KP happens one time per day. Sometimes twice, sometimes 0.. Attached are logs if you're okay to have a look.. My High Sierra install is a mix of several methods, so that's why I wanted to have a go with yout tutorial. Archive.zip
Administrators MaLd0n Posted December 20, 2019 Author Administrators Posted December 20, 2019 [ref]chicoray[/ref], is about nvidia web driver check if have update -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Minipomy Posted December 20, 2019 Posted December 20, 2019 Minipomy, post one photo [ref]MaLd0n[/ref], this one only the default clover files from the olarilla mojave 10.14.6 installer (config2.plist) https://drive.google.com/open?id=1gws2dTDRiaSIhF8mR_39KebaX3N38so2 this one contains the default Clover Notebook Chipset Broadwell https://drive.google.com/open?id=1lZpSg_GN75J16Rac2hnMQFqQJjYUniVL
Administrators MaLd0n Posted December 20, 2019 Author Administrators Posted December 20, 2019 [ref]Minipomy[/ref], no idea -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Minipomy Posted December 21, 2019 Posted December 21, 2019 Minipomy, no idea [ref]MaLd0n[/ref], Any recommendation? maybe EFI folder with some strange kext? The kernel panic happens when you raise the IGPUs in this case the Intel HD 5500. It is clear that do not change any value of the plist or use any fake-id or platform-id Additionally, when you had installed high saw, do not use whatever green I used inteldvmtprealloc with another kext but I don't know if the video kext are the problem Added in 38 minutes 47 seconds: Minipomy, no idea [ref]MaLd0n[/ref], good news! I did a little research and I found that it is not recommended to use FakeSMC with VitualSMC I deleted the VirtualSMC and I opened the installer ..... however it looks a bit broken https://drive.google.com/open?id=13TtzLHKjSrCGmMd4nwhxLdGz4sqis-rl
Administrators MaLd0n Posted December 21, 2019 Author Administrators Posted December 21, 2019 [ref]Minipomy[/ref], need a video patch fo solve it -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Minipomy Posted December 21, 2019 Posted December 21, 2019 need a video patch fo solve it [ref]Hey MaLd0n[/ref], i'm using this config.plist from rehab github still with no luck config.rar
