Administrators MaLd0n Posted October 12, 2019 Author Administrators Posted October 12, 2019 [ref]NOTORIOUS VR[/ref], u need extract files --Run_Me RunMe.app -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
thetristaan Posted October 12, 2019 Posted October 12, 2019 Hello, Gigabyte 85 D3H motherboard with ATI 5450 graphics card. Graphics and ethernet not working. Any solution?
Administrators MaLd0n Posted October 13, 2019 Author Administrators Posted October 13, 2019 [ref]thetristaan[/ref], use dpci manager what lan card u have -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
NOTORIOUS VR Posted October 13, 2019 Posted October 13, 2019 NOTORIOUS VR, u need extract files --Run_Me Done. Send me Saschas-iMac.zip
Administrators MaLd0n Posted October 13, 2019 Author Administrators Posted October 13, 2019 [ref]NOTORIOUS VR[/ref], DSDT.aml.zip generate one ssdt for nativePM https://Olarila.com/forum/viewtopic.php?f=28&t=10897 add shikigva=60 in bootargs for hardware accel -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
NOTORIOUS VR Posted October 13, 2019 Posted October 13, 2019 generate one ssdt for nativePM viewtopic.php?f=28&t=10897 add shikigva=60 in bootargs for hardware accel Thanks, I have done this but it tells me the CPU type is wrong when I run the script. I believe my CPU should be iMac12,1 or 12,3 which is an option but when I choose it my system doesn't boot into the OS anymore. I went ahead anyway with the generation and copied both file to /ACPI/patched is that correct? Or do I need to find another way to force iMac 12,x?
Administrators MaLd0n Posted October 13, 2019 Author Administrators Posted October 13, 2019 [ref]NOTORIOUS VR[/ref], try with -no_compat_check bootargs some smbios loose support, if don't work use imac13,2 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
NOTORIOUS VR Posted October 13, 2019 Posted October 13, 2019 ome smbios loose support, if don't work use imac13,2 This is the SMBIOS I have. When I run the script I get this output warning: ssdtPRGen.sh v0.9 Copyright (c) 2011-2012 by † RevoGirl v6.6 Copyright (c) 2013 by † Jeroen v15.6 Copyright (c) 2013-2019 by Pike R. Alpha ----------------------------------------------------------- Bugs > https://github.com/Piker-Alpha/ssdtPRGen.sh/issues < gDataPath: /Users/sascha/Library/ssdtPRGen/Data System information: Mac OS X 10.14.6 (18G103) Brandstring 'Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz' Scope (_PR_) {220 bytes} with ACPI Processor declarations found in the DSDT (ACPI 1.0 compliant) Generating ssdt.dsl for a 'iMac13,2' with board-id [Mac-FC02E91DDD3FA6A4] Sandy Bridge Core i7-2600K processor [0x206A7] setup [0x0703] With a maximum TDP of 95 Watt, as specified by Intel Number logical CPU's: 8 (Core Frequency: 3400 MHz) Number of Turbo States: 4 (3500-3800 MHz) Number of P-States: 23 (1600-3800 MHz) Injected C-States for CPU0 (C1,C3,C6,C7) Warning: 'cpu-type' may be set improperly (0x0703 instead of 0x0603) Error: board-id [Mac-FC02E91DDD3FA6A4] not supported by Sandy Bridge – check SMBIOS data / use the -c option Do you want to continue (y/n)? n I said yes and generated the file anyway. Is that ok? Also, is it ok to update to Catalina and copy over same CLOVER folder after (if needed)?
Administrators MaLd0n Posted October 13, 2019 Author Administrators Posted October 13, 2019 [ref]NOTORIOUS VR[/ref], no problem, ignore it and check if PM work good -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Deferia Posted October 14, 2019 Posted October 14, 2019 Hi, I finally managed to install Mojave. But i can't get Clover to work. I have too SSD one with windows and the other with Mojave. I have install Clover on the Mojave SSD but the old windows mbdr is still here ( the sdd was use with windows before) How can i erase the ols mbr and replace it with clover? From now i have to use my usb stick to boot... Thanks for your help.
Administrators MaLd0n Posted October 14, 2019 Author Administrators Posted October 14, 2019 [ref]Deferia[/ref], use Olarila clover folder to ur chipset, dont need install clover, just paste efi folder into efi partition -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Deferia Posted October 15, 2019 Posted October 15, 2019 MaLd0n it's not working. My old windows MBR is taking the lead. I have to boot with the clover on my usb key. But everething is working. I have to use the igpu instead of my 1070. Hope nvidia is going to release drivers soon...
Administrators MaLd0n Posted October 15, 2019 Author Administrators Posted October 15, 2019 [ref]Deferia[/ref], forget nvidia in macos use efi folder from ur usb stick -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
NOTORIOUS VR Posted October 16, 2019 Posted October 16, 2019 NOTORIOUS VR, DSDT.aml.zip (14.8 KiB) Downloaded 2 times generate one ssdt for nativePM viewtopic.php?f=28&t=10897 add shikigva=60 in bootargs for hardware accel Well I'm not sure what it is about your EFI folder but my GTX670 doesn't seem to be accelerated at all... video is extremely sluggish, even just resizing windows is very slow. Sleep is not working either. Any ideas?
Administrators MaLd0n Posted October 16, 2019 Author Administrators Posted October 16, 2019 [ref]NOTORIOUS VR[/ref], some hardware loose support u need check if ur system version support ur nvidia card -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
blu3_v2 Posted October 26, 2019 Posted October 26, 2019 Hi, I am looking to install macOS 10.15 Catalina on my Series 5 system. I have attached a dump taken from Clover. Could you please provide a patched DSDT and Clover folder for me to complete the Install. Cheers Specs: GA-P55A-UD4P - i5 750 - GT710 DSDT.zip
Administrators MaLd0n Posted October 26, 2019 Author Administrators Posted October 26, 2019 [ref]blu3_v2[/ref], DSDT.aml.zip Use Olarila efi folder for serie 5 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
blu3_v2 Posted October 26, 2019 Posted October 26, 2019 Use Olarila efi folder for serie 5 Thanks for the DSDT. I tried booting the macOS Catalina Installer from a USB containing the Olarila CLOVER folder in EFI, but received a Kernel Panic after Unsupported CPU and Unsupported PCH messages. Any ideas how to fix this?
Administrators MaLd0n Posted October 26, 2019 Author Administrators Posted October 26, 2019 [ref]blu3_v2[/ref], use nullcpupm kext NullCPUPowerManagement.kext.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
snaky90 Posted October 29, 2019 Posted October 29, 2019 Using Olarila Catalaina or Mojave image, on Sony Vaio Pro 13 (haswell) installer stucks on "VoodooI2C: Got multitouch matched" "VoodooI2C: Got multitouch preferences" I've downloaded VoodooI2C.kext and add it with synaptics sattellite for this But.... My touchpad it's PS/2 interface any solution ? Thanks !
