Hi Maldon. I recently came across your website while searching for Hackintosh Mojave installation. And seriously, Olarila is the best website for hackintosh build. No other website comes close to Olarila. Great work man. Keep it up. I am gonna donate for sure. I system configuration is " Mobo : Gigabyte B85M Gaming 3, Cpu : Core i5 4690, GPU : Intel HD Graphics 4600. No dedicated GPU". Can you please build the best possible config.plist for my hardware with all the Dsdt, etc according to my hardware. Thanks
[ref]Harshkumar07[/ref], put in clover acpi/patched, reboot and enjoy
[ref]Harshkumar07[/ref], aml, yes, put our hack like one real mac
My Laptop info: MSI GL63-8RD
Mainboard: MS-16P6
SSD: SAM SUNG NVME 981a (OEM - EVO 970+)
Graphic: 630 + GTX1050Ti
Install with USB Installer -create by terminal and using EFI (Olarila)
After installed:
Working:
-Keyboard
-Graphic UHD 630(only 7MB memmory)
-trackpad(not have gesture)
-Thunderbolt 3.0, USB 3.0
-Ethernet, Power information
-Camera.
Not Working:
-HDMI
-Graphic Card Gtx1050Ti
-PCIE
-etc...
https://scontent.fhan3-1.fna.fbcdn.net/v/t1.15752-9/70496516_507607843373728_3637772694813933568_n.png?_nc_cat=109&_nc_oc=AQlqY2XlRSmLy85CH3GmDujK1j6-hUZAfEIGZk4Ia6s_7ma4uTqklkiRe31XW0iqHrZxCpX2zUTzgVsy0FDt7HXT&_nc_ht=scontent.fhan3-1.fna&oh=9c180e9e78f6bc4d064e2bb8c666b19f&oe=5E021A2C
ttps://www.msi.com/Laptop/GL63-8RD.html
Here is my SEND_ME file, so what should I do next?
Send me Hais-MacBook-Pro.zip
[ref]haitrvn[/ref], DSDT.aml.zip
check my signature, useful links
How are you @MaLd0n,
LCD brightness broke for me in Catalina working perfectly in Mojave. My laptop is ASus G750JX with Nvidia GTX770m native support in MacOS. The Integrated Intel GFX has been disabled by Asus a good thing for me.
Attached is the send me files from Catalina. Do you you need the send me files from Mojave to?
Edited:
Forgot to mention and I have to have AppleBacklightFixup.kext for LCD brightness to work in Mojave so this is what is broken in Catalina. Is there a way to re-compile the AppleBacklightFixup.kext source in Catalina to work or is there way more to it than just re-compiling the source?
Send me osxfr33ks-MBP.zip
OP-LP3 OverPowered Laptop 17 inch, i7-8750H, 32GB memory, 256GB NvMe stock with windows 10 and added 512GB NvMe Samsung 970 Pro with MacOS 11.2.1, OpenCore 0.6.7.   New Asus Pro WS X299 Sage II intel i9-10980XE 18 core beast Big Sur 11.2.1. OpenCore 0.6.7,  Asus Z390-E i9-9900K 64GB G.Skill Ripjaws Sapphire Pulse RX580, Asus Sabertooth X79 (4) E5-2697 v2 (12 Core), Asus Maximus VIII Hero Alpha i7-7700K 64GB Corsair 2400, Asus Z97-Deluxe i7-4790K, Gigabyte Z77X-UP5-TH i7-3770k, Asus Maximux Formula Special Editions with Rampage Formula Bios conversion, Gigabyte GA-EP35-DS4, GA-EP45-UD3P, GA-G41M-ES2L, GA-Z68X-UD4-B3 and Quo MB.  MAC PRO EARLY 2008, MacPro Late 2012. Asus Notebooks: G51JX i7-720QM, G74SX-XT1 i7-2630QM, Asus G750JX-DB71 Haswell Processor i7-4700HQ GTX 770M 3GB (4).  Dell Laptops D820, D830, XPS M1530 (6), Dell 13-1567 (4), Older processors  i7 (3770K/4770k/6700k/7700K).  Older GFX Cards:  EVGA GT-640, EVGA GTX 760, EVGA GTX 770 (six),
[ref]osxfr33k[/ref], whatevergren kext work on brightness now
Unread post by MaLd0n » 29 Sep 2019, 20:48
osxfr33k, whatevergren kext work on brightness now
Actually not true for Nvidia only Laptop with Built in Intel disabled will not work without Rehabman's AppleBacklightFixup.kext. Anyhow good news. Problem solved sorry about all the noise above.   It won't work in MacOS beta software so there is a bootflag to make it work '-applbklbeta'.  But for the future just want to make sure the Nvidia Laptops that depend on this for backlight will still be supported and if AppleBacklightFixup.kext will no longer work in Future MAcOS then we need WEG to support exactly what AppleBacklightFIxup.kext does. If we can figure that out maybe a hotpatch in Clover? WEG Documentation does mention if some Injector is still needed to disable WEG Intel injector. From Wiki. applbkl=0 boot argument to disable AppleBacklight.kext patches for IGPU. In case of custom AppleBacklight profile needed as in my case.
Hi, Maldon. First, I would like to say thank you for your work and all Oralila Team. This is the best hackintosh I've ever use.
Can you help me to fine tuning my dsdt? And how to get monitoring apps like hwsensor works?
This is my PC specs:
CPU: Core i7 2700K
Mainboard: Asus P8Z77I-Deluxe
GPU: RX Vega 56
OS: Mojave 10.14.6 vanilla from app store with dosdude1 patcher
Clover: Olarila Sandy Bridge
Currently Not Working:
Sleep
Hardware sensor
HDMI audio volume
Oh, 1 another question, can I upgrade to Catalina without clean install?
Thank you so much.
Send me Edwins-iMac.zip
[ref]abawiranta[/ref], DSDT.aml.zip
generate one ssdt for good power management
https://Olarila.com/forum/viewtopic.php?f=28&t=10897
sensors u just need plugins fakesmc or virtualsmc
hdmi don't have volume control under macos, not native
Hi,
I'm trying to install Mojave on my I5-4670K, Z87 Pro 3, 4x4gb ddr3, GTX 1070 but my screen frreze on RTC : Only.
I can't reach the installer.
I use Olarilla Mojave and rtc fix is already on. Clover is already set with some flag. I havent done any modification in clover options.
Thz for your help.
[ref]Deferia[/ref], Extract tables with F4 key in Clover boot screen, files generated in Clover/Acpi/origin, post here!
Hi,
It’s done but i’m now looking for someone with a mac Because my Windows can’t read my usb key done with win32. He ask me to format the key
[ref]Deferia[/ref], yes, windows dont load it, just boot from usb
Yes but i have to read the usbkey in ordre to get the extracted table.
Sorry for my bad english but my question is how can i send the files on the forum. I can't read the usbkeys
Hi all,
I have tried booting my already running/booting Sand Bridge with the Clover Folder from the first post. It booted, but there was a few strange things I noticed right away. My video did not seem accelerated anymore (GTX 670) and also my DP audio was not working correctly (choppy).
What can a hackintosh noob do to get that sorted.
Full run down of specs:
2600K
GA-Z77N-WIFI with wifi replaced > AzureWave AW-CB160H Broadcom BCM94360HMB
PNY GTX 670 2GB
43" Philips 4k Monitor via DP (also for audio currently).
Samsung 500GB 860EVO
Origin Folder.zip
