oloye Posted July 6, 2019 Posted July 6, 2019 I have hp EliteBook 840 g2 core i7 5600U cpu display intel hd graphics 500 AMD Radeon R7260X ram 12gb I want to install hackintosh but I don't have any system running mac os that I can use to do the clover config kindly help with how to configure efi using windows
Administrators MaLd0n Posted July 6, 2019 Author Administrators Posted July 6, 2019 [ref]oloye[/ref], https://Olarila.com/forum/viewtopic.php?f=50&t=8685 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
pepe21 Posted July 11, 2019 Posted July 11, 2019 [ref]MaLd0n[/ref], I'm having some problems with the AppStore. My iCloud works fine, but I can't get the AppStore to work. It says I can't connect to the AppStore, and when I go and hit the update button on an application, ask me for my Apple ID and password, but it doesn't begin to download the update. A wheel appears and after a few seconds, the update button next to the app appears again, so I can't update any app. Also I can't download any app from the AppStore as well. I have configured the SMBIOS with a new Serial Number, new SmUUID and new Board Serial Number. I did repair permissions and rebuild cache, and rebooted, configured iCloud and stuff. I experimented problems with iBooks also, when I log in. Any ideas? Thanks for the help and support!!!
Administrators MaLd0n Posted July 11, 2019 Author Administrators Posted July 11, 2019 [ref]pepe21[/ref], generate new smbios, delete files into library/preferences/systemconfiguration and reboot -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
pepe21 Posted July 11, 2019 Posted July 11, 2019 [ref]MaLd0n[/ref], when I do it, my computer start freezing after reboot and UBS wifi adapter doesn't works, so I can't reconnect to internet. I put the files back in the folder. The list of files is this one: -ApplicationFirewallStartup.bundle -CaptativeNetworkSupport.bundle -EAPOLController.bundle -InterfaceNamer.bundle -InternetSharingPreference.bundle -IPConfiguration.bundle -IPMonitor.bundle -KernelEventMonitor.bundle -LinkConfiguration.bundle -PPPController.bundle -PreferencesMonitor.bundle -PrinterNotifications.bundle -QoSMarking.bundle Maybe deleting some in stead of everyone of them? Thanks!
Administrators MaLd0n Posted July 11, 2019 Author Administrators Posted July 11, 2019 [ref]pepe21[/ref], library in the root of the hd -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
pepe21 Posted July 12, 2019 Posted July 12, 2019 [ref]MaLd0n[/ref], great, worked now. Thank you so much, MaLd0n!
ancientbriton Posted July 28, 2019 Posted July 28, 2019 MaLd0n Thanks for your help just over a year ago. I now have a new laptop and wonder if you can help with a DSDT. HP Pavilion 15-cc665cl Intel i7 8550U @ 1.8GHz - 4.0 GHz 12GB Ram RTL8111 Ethernet Insyde BIOS F.32 Intel Graphics UHD 620 Intel Wifi 3168 - Yes, I know I need to replace this. I bought you a beer last year on May 27, 2018 18:53:16 EDT. I'd like to buy you another. Thanks
Administrators MaLd0n Posted July 28, 2019 Author Administrators Posted July 28, 2019 [ref]ancientbriton[/ref], hey send me files --Run_Me RunMe.app -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
ancientbriton Posted July 28, 2019 Posted July 28, 2019 Wow, you are quick Attached, thanks Send me Nigels-MBP.lan.zip
Administrators MaLd0n Posted July 28, 2019 Author Administrators Posted July 28, 2019 [ref]ancientbriton[/ref], replace full efi, reboot, check if work EFI.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
ancientbriton Posted July 28, 2019 Posted July 28, 2019 Some successes, but still some issues: Bluetooth works, which it didn't before. No Audio through speakers, which I did have working. Bluetooth audio to my Bose portable speakers only works if I select the BT speaker as both input and output and is poor quality. This only works if I have the System Preferences -> Sound -> Input pane open. Audio Fn keys seem to work ok I now have a Backlight slider under preferences which works. Auto-Brightness doesn't work, but maybe that's because there is no light sensor. Brightness adjustment keys (fn-F2,fn-F3) do not work. System Information says I have 1 processor with 4 cores, not 4 with 8. This was working: Model Name: MacBook Pro Model Identifier: MacBookPro14,1 Processor Name: Intel Core i7 Processor Speed: 1.99 GHz Number of Processors: 1 Total Number of Cores: 4 L2 Cache (per Core): 256 KB L3 Cache: 8 MB Hyper-Threading Technology: Enabled Memory: 12 GB Boot ROM Version: 196.0.0.0.0 Apple ROM Info: Apple ROM Version. BIOS ID:MBP141.88Z.F000.B00.1905281616 EFI Version:196.0.0.0.0 Built by: Clover SMC Version (system): 2.43f6 Touchscreen works, including 2 finger zoom and 2 finger scroll Trackpad works, but no 2 finger actions Webcam works Card reader slot doesn't work, and I don't care. My PCI devices now show up in System Info, which they did not before Ethernet works great at 1Gbps No battery information and no ability to have icon on bar: Battery Information: Charge Information: Charging: No Battery Installed: No System Power Settings: AC Power: System Sleep Timer (Minutes): 1 Disk Sleep Timer (Minutes): 10 Display Sleep Timer (Minutes): 10 Sleep on Power Button: Yes Wake on LAN: Yes AutoPowerOff Delay: 28800 AutoPowerOff Enabled: 1 Current Power Source: Yes DarkWakeBackgroundTasks: 1 Display Sleep Uses Dim: Yes GPUSwitch: 2 Hibernate Mode: 3 High Standby Delay: 86400 PrioritizeNetworkReachabilityOverSleep: 0 ProximityDarkWake: 1 Standby Battery Threshold: 50 Standby Delay: 10800 Standby Enabled: 1 TCPKeepAlivePref: 1 Hardware Configuration: UPS Installed: No AC Charger Information: Connected: Yes Charging: No Both USB 3.0 ports work. I don't know if USB-c works, as I have nothing to test it with. Keyboard backlight key works, but auto control does not. I don't care. It's better than it was. What next?
Administrators MaLd0n Posted July 28, 2019 Author Administrators Posted July 28, 2019 [ref]ancientbriton[/ref], extract new send_me -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Administrators MaLd0n Posted July 28, 2019 Author Administrators Posted July 28, 2019 [ref]ancientbriton[/ref], audio, alc295, check here https://Olarila.com/forum/viewtopic.php?f=28&t=9788 Hotkeys https://Olarila.com/forum/viewtopic.php?f=28&t=8396 battery https://Olarila.com/forum/viewtopic.php?f=28&t=8208 Added in 1 minute 35 seconds: [ref]MaLd0n[/ref], one little fix _L6F DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
ancientbriton Posted July 29, 2019 Posted July 29, 2019 Getting pretty good. Audio working well - Set to 13 Brightness controls working _Q10 & _Q11 Battery now showing, but no Sleep Timer slider. Seems to sleep when lid is shut. Touchpad is now found, and can be configured in System Prefs. However no 2 or 3 finger actions work. They do work on the touchscreen, and the configuration parameters seem to control touch screen options. Is it possible to have both working. If I connect a Bluetooth trackpad, that works alongside the touchscreen. Of these, the one I'd really like to fix is the trackpad. I attach screen shots of /Library/Extensions and CLOVER/kexts/other. Let me know if there is anything there that I should remove. Thanks for your help Screen Shot 2019-07-29 at 7.36.47 PM.pdf Screen Shot 2019-07-29 at 7.43.48 PM.pdf
Administrators MaLd0n Posted July 29, 2019 Author Administrators Posted July 29, 2019 [ref]ancientbriton[/ref], dontneed use kexts into library/extensions, remove all and rebuild cache sudo kextcache -i / https://i.imgur.com/ESDgXZN.png' alt='IMGUR>'> -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Thelion Posted August 9, 2019 Posted August 9, 2019 I'm use the Olarila Sierra and need to install Mojave but I have unsupported CPU problem any fix .. my laptop is Icer e1 570 Intel core i3 3217u Intel graphics 4000
Administrators MaLd0n Posted August 9, 2019 Author Administrators Posted August 9, 2019 [ref]Thelion[/ref], post one photo -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
