Administrators MaLd0n Posted August 19, 2021 Author Administrators Posted August 19, 2021 3 hours ago, Tahsin Faiyaz Sayor said: Then, how can I make the EFI file on Windows? use our premade folder https://www.olarila.com/topic/5676-folders-for-all-chipsets-clover-and-opencore/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
uran0s Posted October 27, 2021 Posted October 27, 2021 Olá MaLd0n, Actualizei o opencore para a ultima versão e as kexts, e não consigo dar boot. Experimentei a retirar o ficheiro dsdt que criaste para mim e já arranca. Será que terá de ser feito outro ajustado ao novo opencore? Deixo mensagem da tela. IMG_3798.jpg.zip
Administrators MaLd0n Posted October 27, 2021 Author Administrators Posted October 27, 2021 Sim -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
uran0s Posted October 27, 2021 Posted October 27, 2021 27 minutes ago, MaLd0n said: Sim Ok, envio ficheiro criado com o run me de como está actualmente. download Será necessário mexer em outras configurações no config.plist para ficar preparado para o Monterey? Outra questão, quando faço sleep, aparentemente tudo funciona bem, mas ao fim de umas horas o pc reinicia sozinho. Se nunca fizer sleep, funciona sempre bem durante o tempo que for necessário. Obrigado desde já.
uran0s Posted October 28, 2021 Posted October 28, 2021 On 10/27/2021 at 2:23 PM, MaLd0n said: Sim Quando me poder ajudar, deixei os ficheiros no post acima. Obrigado.
robcodemax Posted November 27, 2021 Posted November 27, 2021 (edited) Hi @MaLd0n ...I am having random Reboots just after APIC i.e before loading VoodooTSCSync....It reboots. This happens 3 to 4 times and then it boots normally. Then again when I restart it happens 3 to 4 times and then boots normally. I have tried many steps but nothing works. My powermanagement works properly after booting. I have removed the kexts so that the size is small to upload here. Please help me.... If I don't use Voodootscsync it never makes into the mac. I really don't know what to do now..Please let me know if you need any other files.. Motherboard : Huananzhi X79 Deluxe CPU : E5 1650 V2 RAM : 32 GB Graphics Card : GT 710 / GTX 1060 Disabled using SSDT Send me Mac-Pro.zip Edited November 27, 2021 by robcodemax
Administrators MaLd0n Posted November 28, 2021 Author Administrators Posted November 28, 2021 12 hours ago, robcodemax said: Hi @MaLd0n DSDT.aml.zip use last version https://github.com/acidanthera/CpuTscSync/releases/tag/1.0.5 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
robcodemax Posted November 29, 2021 Posted November 29, 2021 (edited) On 11/28/2021 at 6:52 AM, MaLd0n said: DSDT.aml.zip 10.34 kB · 1 download use last version https://github.com/acidanthera/CpuTscSync/releases/tag/1.0.5 Thankyou verymuch for the reply. Because of you My inbuild Audio ALC 892 is working...Thanks a ton.....I had been trying to get the audio working for the past 1 month...You solved it in one reply... Regarding the random reboot while starting I tried CpuTscSync but it gave a kernel panic. Screenshothttps://drive.google.com/file/d/1fYLDcc_LKEt_VrC_AF2njdpboXANQCPw/view I used the DSDT Edited November 29, 2021 by robcodemax
Administrators MaLd0n Posted November 29, 2021 Author Administrators Posted November 29, 2021 4 hours ago, robcodemax said: Thankyou verymuch for the reply. Archive.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
robcodemax Posted November 29, 2021 Posted November 29, 2021 1 hour ago, MaLd0n said: Archive.zip 195.12 kB · 1 download I really appreciate the time that you have given into this issue. Cputscsync has never worked for me I don't know why. I tried these two files and got the same kernel panic.
Administrators MaLd0n Posted November 29, 2021 Author Administrators Posted November 29, 2021 try with unc fix -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
robcodemax Posted November 29, 2021 Posted November 29, 2021 (edited) On 11/29/2021 at 8:35 PM, MaLd0n said: try with unc fix I removed the UNC0 entry from DSDT and also did a USB Mapping again and now the problem is solved Thank you very much for your help... You are good at what you do The most important thing was sound and you got it to work.. For those facing Kernel Panic using CPUTSCSync 1.0.5. Please use CPUTSCSync 1.0.3, I used 1.0.3 and my kernel panic is gone. Don't use 1.0.5 Thanks Once Again Motherboard: Huananzhi x79 Deluxe Processor: E5 1650 V2 DDR3 RAM: 32 GB Graphics Card: GT 710 2 GB Edited December 8, 2021 by robcodemax
robcodemax Posted December 12, 2021 Posted December 12, 2021 (edited) On 11/29/2021 at 8:35 PM, MaLd0n said: try with unc fix I just manually removed all the unused cores from DSDT like SCK1 , SCK2 and SCK3 using using Rehabman's MacIasl and then put it in ACPI folder and now everything works without any problem. No more kernel panic. Thank you very much. Those who are using 6 Cores 12 Threads CPU and Huananzhi X79 or Chinese X79 Motherboard can use DSDT_ROBERT.aml Others can use DSDT_OLARILA.aml which will support more cpu cores. You can edit this DSDT and remove the unused cores like I have shown below, just delete those entries DSDT_ROBERT.aml.zip DSDT_OLARILA.aml.zip Edited December 13, 2021 by robcodemax
Administrators MaLd0n Posted December 12, 2021 Author Administrators Posted December 12, 2021 1 hour ago, robcodemax said: No more kernel panic Nice. Enjoy! -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
robcodemax Posted December 14, 2021 Posted December 14, 2021 Hi @MaLd0n....I have one more question I have two graphics card in Slot 1 I have GTX 1060 which I have disabled using SSDT and in slot-2 I have GT 710. I want to know is there anyway to get the verbose showing in GT 710 currently verbose is shown in GTX 1060.
Administrators MaLd0n Posted December 14, 2021 Author Administrators Posted December 14, 2021 7 hours ago, robcodemax said: I want to know is there anyway to get the verbose showing in GT 710 currently verbose is shown in GTX 1060. 1060 is disabled? check with ioreg -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
robcodemax Posted December 14, 2021 Posted December 14, 2021 (edited) 17 hours ago, MaLd0n said: 1060 is disabled? check with ioreg Yes It is disabled. I checked Ioreg as well. One more issue is that the machine is not able to wake from sleep. The screen Keyboard and Mouse never comes on. Then I have to forcibly shutdown and then restart Edited December 15, 2021 by robcodemax
robcodemax Posted December 19, 2021 Posted December 19, 2021 On 12/14/2021 at 5:36 PM, MaLd0n said: 1060 is disabled? check with ioreg Is it possible to get sleep working in x79 motherboard.. Mine goes to sleep but never comes back.. No screen no keyboard no mouse
Administrators MaLd0n Posted December 19, 2021 Author Administrators Posted December 19, 2021 sleep don't work good on x79 platforms -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
robcodemax Posted January 11, 2022 Posted January 11, 2022 @MaLd0n Is there a way to show the NVMe drive as Internal Drive using DSDT Patch? or SSDT
Administrators MaLd0n Posted January 11, 2022 Author Administrators Posted January 11, 2022 4 hours ago, robcodemax said: @MaLd0n Is there a way to show the NVMe drive as Internal Drive using DSDT Patch? or SSDT yes -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
robcodemax Posted January 11, 2022 Posted January 11, 2022 5 hours ago, MaLd0n said: yes Ok Thanks I figured it out 1
leotbmc Posted March 13, 2023 Posted March 13, 2023 (edited) Hi guys, I got the split screen after installing the opencore legacy patcher. Does anyone know what can it be? Intel hd 4000 Laptop t430 - 1366x768 Edited March 13, 2023 by leotbmc
Administrators MaLd0n Posted March 14, 2023 Author Administrators Posted March 14, 2023 Check if have CSM option and enable. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
boof Posted July 14, 2024 Posted July 14, 2024 (edited) Hi MaLd0n. After using your sandybridge EFI folder with no ACPI mod on big sur, I get this kernel panic on debug mode. Can u figure out the problem? Asrock Z68 Extreme4 Intel Xeon E3 1230 v2 GTX 650 Edited July 14, 2024 by boof
