22 minutes ago, iFabio said:
removed AptioMemoryFix.efi and installed OcQuirks.efi all working
good
just enjoy
On 3/9/2018 at 7:07 AM, MaLd0n said:
 -Donations with PayPal
https://tinyurl.com/r2bvzm7
-Donations with Bitcoin
33HeGCuCSh4tUBqdYkQqKpSDa1E7WeAJQ3
-Donations with PicPay
@danielnmaldonado
1--Download Olarila Image--
https://www.olarila.com/topic/6278-new-olarila-images/
2--Tutorial Install MacOS with Olarila Image, Step by Step, Install and Post Install--
https://www.olarila.com/topic/5794-guide-install-macos-with-olarila-image-step-by-step-install-and-post-install-windows-or-mac/
3--EFI Folders for Chipsets--
https://www.olarila.com/topic/5676-folders-for-all-chipsets-clover-and-opencore/
4--DSDT Patch Request--
https://www.olarila.com/forum/17-dsdt-patch-requests/
If you are a donor use a personal room and support!
https://www.olarila.com/forum/90-?-donators-room/
-Credits and thanks to the old and new people in the community who developed patches, kexts and bootloaders!
Slice, Kabyl, usr-sse2, jadran, Blackosx, dmazar, STLVNUB, pcj, apianti, JrCs, pene, FrodoKenny, skoczy, ycr.ru, Oscar09, xsmile, SoThOr, RehabMan, Download-Fritz, Zenit432, cecekpawon, Intel, Apple, Oracle, Chameleon Team, crazybirdy, Mieze, Mirone, Oldnapalm, netkas, Elconiglio, artut-pt, ErmaC, Pavo, Toleda, Master Chief and family, bcc9, The King, PMheart, Sherlocks, Micky1979, vit9696, vandroiy2013, Voodoo Team, Pike R. Alpha, lvs1974, Austere.J, CVad and many, many, many others!
hey Mald0n
I have an audio problem not detected in Run me.app and hackintoshtool. i have followed the installation steps but it doesn't work. I also have a problem with the brightness hotkey remapping. When I patch text there is a problem that it can't be saved
mac os catalina 10.15.3
dell inspiron 3421 intel i3 1,8ghz ram 4gb vga intelhd4000 and nvidia 625m wificard AR9565
intelHD4000 and wificard work
does not work
sleep
brightness hotkey
audio is not detected
PCI not detected
help me Mald0n
I need a patched DSDT
Send Me.zip
4 hours ago, IGosa Bagus Yuniarta said:
My audio not working, i check use manufacture page ALC3221 and brigthness hotkey remapping after I copy patch can't save
On 9/22/2020 at 9:41 AM, MaLd0n said:
thanks mald0n
audio works fine and hotkeys work fine
hotkey brightness works but when I press Fn + F5 to increase the direct lighting it increases to the maximum and I press Fn + F4 to decrease the direct lighting to decrease to a minimum, even though I press it once
I've tried to copy and paste the patch but still unchanged
Olá MaLd0n,
Não sei se têm acontecido com mais pessoas, mas estava a fazer um benchmark com o geekbench em Metal à minha Vega 56, e consigo 59423 com o DSDT que me criaste.
Experimentei remover o DSDT e fazer reboot e dá 81275, o que poderá ser?
Não sei se é normal ou não, mas noto que a Vega sempre que abro um vídeo fica ao máximo Mhz da memória RAM, e só passa se reiniciar o hack.
uran0s-macpro.zip
Edited by uran0s
5 hours ago, uran0s said:
Olá MaLd0n,
quando se ativa o gerenciamento de energia, etc que os problemas começar a aparecer.
a galera usa uma ssdt pra correção desse problema
Ok. Então devo usar à mesma o DSDT? E que SSDT devo usar para correcção do problema?
veja qual o pci adress e adiciona o valor Force_Load_FalconSMUFW = 01
Com este comando já ficou a dar os 82 000 no geekbench :), obrigado.
O que acontece agora é que apenas se mantém a 500mhz em idle se tiver os monitores na resolução máxima 2k, se tento mudar para 1k fica sempre a 920mhz... porque será?
Outra coisa que noto é, em System Information>Graphics indica que a placa está a x8 no PCIe Lane com o DSDT, sem DSDT indica x16.
deixe me ver esse dsdt
@MaLd0n estou tentando instalar o HS ,porém,após instalar,não consigo bootar com a basta EFI do meu chipset (haswell) . Me dá uma ajuda?
i7 4790 + Z87 Gryphon + Gtx 1060 3gb
3 hours ago, uran0s said:
era para mim? é para correr o runme e postar aqui?
sim
posta uma foto do erro
This dont work on my acer all in one .
I see a halted error and much text and thats it.
My all in one is intel quad core 4 gb memory and ati hd 4670 and 1tb hdd.
Edited by Jacco Brand
post one photo in error screen
17 hours ago, MaLd0n said:
sim
Peço desculpa, não tinha reparado antes.
Dei boot com o DSDT que criaste, corri o runme. Juntamente envio printscreen da gráfica com o DSDT.
Sem DSDT, o sistema está a ler o SSDT para a gráfica, em que activa o framebuffer "ATY,Kamarang", julgo ser o correcto?
Com DSDT activa o genérico, "ATY,AMD,RadeonFramebuffer".
PS: Eliminei a kext AppleALC.kext das pastas para não ultrapassar os 2,9M de upload por aqui.
Até já,
uran0s com DSDT.zip Printscreen Gráfica.zip
Envio também runme com boot sem DSDT nenhum.
uran0s sem DSDT.zip
Flw!
I have Catalina 15.7 and Big Sur Beta 9 working with Opencore 6.1. But booting Big Sur is very slow compared to Catalina, so I've tried updating to Opencore 6.2 but it's going to a black screen. I haven't seen any skylake working config.plist files yet to try either. Any suggestions?
Skylake system: i6500+RX570+MSI Z170A
Post one Full Dump
https://www.olarila.com/topic/10301-olarila-runme-dumper/
https://olarila.com/files/Utils/RunMe.app.zip
