Hello Maldon
from the GUI of the config.plist how to set up the various hard disks
Hi!
This are my send me files.
https://www51.zippyshare.com/v/DEL0hjPf/file.html
I installed Mojave on my Asus UX410UA Laptop, because I have an Intel 620.
Audio, microphone, touchpad and FN keys are not working. I managed to get the battery indicator, but that's pretty much of what I achieve. :help
Neither Bluethoot and wifi, but that's because I need to buy a different model. I'm using an USB ethernet adapter and works like charm! :D
Thank you so much for the help and support! You deserve the beer! ;)
[ref]pepe21[/ref], use it with last clover version, reboot and extract new send_me
CLOVER.zip
pepe21, use it with last clover version, reboot and extract new send_me
CLOVER.zip
MaLd0n, I installed again the last Clover version (config set as default) and copied the content of the CLOVER.zip you attached on the previous comment. Now audio is working fine, and also the volume controls on the FN keys, but the bright keys are not working properly, I just can turn on/off the screen, but not get up/down the brightness on the screen.
The touchpad is not working, and also Siri is malfunctioning.
When I turn on the computer after the reboot, an iCloud error jumped to the screen, seems like my password wasn't stored.
Any clues about how to fix this?
This is the send_me generated after the reboot.
https://www83.zippyshare.com/v/coG0ikkR/file.html
Thank you again for the support! :):guitar
[ref]pepe21[/ref], replace dsdt
rebuild cache
configure ur hack again, icloud etc
[ref]iFabio[/ref], DSDT.aml.zip
(38.86 KiB) Downloaded 2 times
rebuild cache
Hi MaLd0n, thank you for everything! The touchpad works like charm now, and I can use a properly Mackintosh experience, but the only problem I face is the one with the Apple accounts. I can log in into iCloud, but I can't download any apps from AppStore, I can't neither use iMessage or FaceTime. iMessage and FaceTime could be disabled for good if there is not an easy fix for that, but I would love to be able to download apps from the AppStore. Any suggestion in order to fix this problem?
Thanks a lot for your time and effort! :guitar:D:guitar
[ref]pepe21[/ref], generate new smbios with clover configurator, run it, and reboot, configure again
iMessage.FaceTime.command.zip
Hi there guys! New Hackintosh venturer here. I'm trying to make a hackintosh out of a Dell Precision T3600. However I'm getting stuck at kexts stall [n] (240s) AppleACPICPU. Any clues as to why this might be happening? Thanks!
[ref]tristan.jorge[/ref], use last clover version and use apfs.efi instead ApfsDriverLoader-64.efi
this clover is only for uefi
Clover_v2.4k_r4919.pkg.zip
Hi again MaLd0n,
I was trying to do a dual boot for OS X Mojave and Windows 10 and when I was installing Windows 10 there was an error and I couldn't complete installation.
I had to format the HHD and now I installed again OS X Mojave, but using the fixes you told me before, is not working...
Would you mind to check out again my RunMe file?
I just did a clean installation with the image, and didn't installed clover or anything, just run the RunMe app, I uploaded the file here
https://www.mediafire.com/file/4p4f24m4cwa97nd/Send_me_Vicentes-MacBook-Pro.zip/file
Thank you again in advice for your support!
[ref]pepe21[/ref], Clover folder and dsdt is same, just use
pepe21, Clover folder and dsdt is same, just use
MaLd0n, I tried 4 times now and I can't manage to get the touchpad working again. The FNKeys works fine and audio as well.
I followed the steps you told me in the comments before, but doesn't fix the touchpad problem, it just doesn't work, I have to use an external USB mouse.
I erase the HDD, partition it in 2, one with 120 GB and APFS for Mojave, the other one with 120GB and FAT 32 for windows.
I install OS X Mojave and then I install Clover (last version) with UEFI only option and RC options enabled.
After that I reboot, replace the cover files and then I execute the RunMe again.
Reboot the system and replace the DSDT in EFI>CLOVER>ACPI>patched, I rebuild cache with sudo kextcache -i / in terminal and reboot the system again.
Touchpad doesn't respond :(:hammer
Do you know what can be happening? Am I doing something wrong?
Here the RunMe:
https://www.mediafire.com/file/3ea1im40x024mg2/Send_me_Vicentes-MacBook-Pro.zip/file
Thanks for your time and support!
MaLd0n,
Instalei uma placa wifi no meu sistema (BCM94360CS2). Aparentemente tudo funciona, wifi e bluetooth, embora não apareça nenhuma informação no PCI List do hardware. Dá para acrescentar?
Envio em anexo ficheiro runme.
uran0s5.zip
Grande Abraço
pepe21, viewtopic.php?f=81&t=8238
MaLd0N, I'm sorry for being so annoying, but I can't fix it neither with this tool. I tried but nothing changes, touchpad still not working.
I wanted to tell you, the first time I uploaded the RunMe to the page I did some previous modifications (this way I could get the battery working) following a guide on another forum, but this guide is not online anymore and I can't manage to get everything as it was before. I've been trying for 2 days now, formatting the drive and starting all over again with different configurations, but nothing works... I can't get the touchpad to work.
This is why I think maybe the files you upload before doesn't work now, because I modified something before the first RunMe I upload, and I can't do that modifications again because I can't find the guide I followed.
Now I did a completely clean installation, I installed Clover with this options:
-Clover for UEFI booting only
-Install Clover in the ESP
-UEFI Drivers:
-AudioDxe-64
-DataHubDxe-64
-FSInject-64
-SMCHelper-64
-VBoxHfs-64
-Install RC Scripts on target volume
After that I run RunMe again, and I uploaded it:
https://www.mediafire.com/file/hsm1ham276ci990/Send_me_Vicentes-MacBook-Pro.zip/file
Could you please help me?
Sorry again for being so insistent with the same problem :hammer , and thanks in advance for the support! :guitar:guitar
