[ref]nafjang[/ref], is a last version? if yes, done
[ref]nafjang[/ref], and error stay there?
[ref]nikhilpal2705[/ref], u don't need use kexts in l/e or s/l/e, put in clover/kexts/other and set inject
[ref]nikhilpal2705[/ref], Someone needs to pay the expense. :lol::mrgreen:
Olá mald0n! Precisava que me criasses um dsdt e configuração do config.plist, por favor.
- Z87n wifi
- i5 4570
- Radeon Vega 56 Pulse
Obrigado, grande abraço!!
pedro.zip
[ref]uran0s[/ref], use somente essa pasta clover com a última versão do clover
CLOVER.zip
Hello Maldon
update 10.14.4 which KextsToPatch should I add for hardware in the signature
uran0s, use somente essa pasta clover com a última versão do clover
]Obrigado Maldon!! :)
Está tudo a funcionar menos o USB 3.0!
Envio novo runme.
Obrigado e grande abraço!
pedro2.zip
[ref]iFabio[/ref],
<dict>
			<key>Comment</key>
			<string>External icons patch</string>
			<key>Disabled</key>
			<false/>
			<key>Find</key>
			<data>
			RXh0ZXJuYWw=
			</data>
			<key>InfoPlistPatch</key>
			<false/>
			<key>MatchOS</key>
			<string>10.13.x,10.14.x</string>
			<key>Name</key>
			<string>com.apple.driver.AppleAHCIPort</string>
			<key>Replace</key>
			<data>
			SW50ZXJuYWw=
			</data>
		</dict>
		<dict>
			<key>Comment</key>
			<string>USB Port Limit Patch 1 ©PMHeart</string>
			<key>Disabled</key>
			<false/>
			<key>Find</key>
			<data>
			g/sPD4cLBAAA
			</data>
			<false/>
			<key>MatchOS</key>
			<string>10.14.4,10.14.5</string>
			<key>Name</key>
			<string>com.apple.iokit.IOUSBHostFamily</string>
			<key>Replace</key>
			<data>
			g/s/D4cLBAAA
			</data>
		</dict>
		<dict>
			<key>Comment</key>
			<string>USB Port Limit Patch 2 ©PMHeart</string>
			<key>Disabled</key>
			<false/>
			<key>Find</key>
			<data>
			QYP/Dw+DlAQAAA==
			</data>
			<false/>
			<key>MatchOS</key>
			<key>Name</key>
			<string>com.apple.driver.usb.AppleUSBXHCI</string>
			<key>Replace</key>
			<data>
			QYP/Pw+DlAQAAA==
			</data>
		</dict>
		<dict>
			<key>Comment</key>
			<string>USB Port Limit Patch 3 ©PMHeart</string>
			<key>Disabled</key>
			<false/>
			<key>Find</key>
			<data>
			g+MP0+NBCd8=
			</data>
			<false/>
			<key>MatchOS</key>
			<key>Name</key>
			<key>Replace</key>
			<data>
			g+M/0+NBCd8=
			</data>
		</dict>
		<dict>
			<key>Comment</key>
			<string>MikeyDriver Patch Assertions</string>
			<key>Disabled</key>
			<false/>
			<key>Find</key>
			<data>
			U291bmQgYXNzZXJ0aW9uIA==
			</data>
			<false/>
			<key>MatchOS</key>
			<key>Name</key>
			<string>com.apple.driver.AppleMikeyDriver</string>
			<key>Replace</key>
			<data>
			AAAAAAAAAAAAAAAAAAAAAA==
			</data>
		</dict>
		<dict>
			<key>Comment</key>
			<string>USB Port Limit Patch 1 ©ydeng</string>
			<key>Disabled</key>
			<false/>
			<key>Find</key>
			<data>
			g/sPD4cWBAA=
			</data>
			<false/>
			<key>MatchOS</key>
			<string>10.14.3</string>
			<key>Name</key>
			<key>Replace</key>
			<data>
			g/s/D4cWBAA=
			</data>
		</dict>
		<dict>
			<key>Comment</key>
			<string>USB Port Limit Patch 2 ©ydeng</string>
			<key>Disabled</key>
			<false/>
			<key>Find</key>
			<data>
			g/sPD4OPBAAA
			</data>
			<false/>
			<key>MatchOS</key>
			<key>Name</key>
			<key>Replace</key>
			<data>
			g/s/D4OPBAAA
			</data>
		</dict>
		<dict>
			<key>Comment</key>
			<string>USB Port Limit Patch 3 ©ydeng</string>
			<key>Disabled</key>
			<false/>
			<key>Find</key>
			<data>
			g+MP0+NBCd8=
			</data>
			<false/>
			<key>MatchOS</key>
			<key>Name</key>
			<key>Replace</key>
			<data>
			g+M/0+NBCd8=
			</data>
		</dict>
		<dict>
			<key>Comment</key>
			<string>Prevent AGDP from loading</string>
			<key>Disabled</key>
			<false/>
			<key>Find</key>
			<data>
			ugUAAAA=
			</data>
			<false/>
			<key>MatchOS</key>
			<key>Name</key>
			<string>com.apple.driver.AppleGraphicsDevicePolicy</string>
			<key>Replace</key>
			<data>
			ugAAAAA=
			</data>
		</dict>
		<dict>
			<key>Comment</key>
			<string>Prevent Apple I2C kexts from attaching to I2C controllers</string>
			<key>Disabled</key>
			<true/>
			<key>Find</key>
			<data>
			U1U5TGFYUT0=
			</data>
			<true/>
			<key>MatchOS</key>
			<key>Name</key>
			<string>com.apple.driver.AppleIntelLpssI2C</string>
			<key>Replace</key>
			<data>
			U1U5TGFYTT0=
			</data>
		</dict>
		<dict>
			<key>Comment</key>
			<key>Disabled</key>
			<true/>
			<key>Find</key>
			<data>
			U1U5TGFYUT0=
			</data>
			<true/>
			<key>MatchOS</key>
			<key>Name</key>
			<string>com.apple.driver.AppleIntelLpssI2CController</string>
			<key>Replace</key>
			<data>
			U1U5TGFYTT0=
			</data>
		</dict>
		<dict>
			<key>Comment</key>
			<string>USB 10.13.6 by PMHeart</string>
			<key>Disabled</key>
			<false/>
			<key>Find</key>
			<data>
			g32IDw+DpwQAAA==
			</data>
			<false/>
			<key>MatchOS</key>
			<string>10.13.6</string>
			<key>Name</key>
			<key>Replace</key>
			<data>
			g32ID5CQkJCQkA==
			</data>
		</dict>
		<dict>
			<key>Comment</key>
			<string>AppleHDA Patch Assertions</string>
			<key>Disabled</key>
			<false/>
			<key>Find</key>
			<data>
			</data>
			<false/>
			<key>MatchOS</key>
			<key>Name</key>
			<string>com.apple.driver.AppleHDA</string>
			<key>Replace</key>
			<data>
			</data>
		</dict>
Added in 31 seconds:
[ref]uran0s[/ref], é só atualizar pro 10.14.4, vai funcionar
Added in 5 minutes 37 seconds:
[ref]uran0s[/ref], USE ESSE DSDT, REINICIE E RODA O RUN_ME DE NOVO
o usb é só atualizar
[ref]uran0s[/ref], parece legal, usb 3 ok agora
Hello Maldon
Thanks for the reply
question: using macOS mojave - Windows 10 - High Sierra from the config.plist how to set it in the GUI
[ref]iFabio[/ref], have all with correct matchOS
[ref]iFabio[/ref], 5HdOout.png
